#1 2024-05-09 20:17
Jeffrey
login
Hello,
I just joined the forum and I have an easy question.
When I installed the OS I opted for the auto login and now I need to change to manual login, so how does one do this.
I really like the OS and have it installed on an older Chromebook (N42) it works fine.
Thanks,
Jeffrey
#2 2024-05-09 22:11
Re: login
The easiest way is to run welcome screen from main menu and use the auto-login button.
