#1 2024-05-05 14:21
lookheart_nohands
why doesn't our XFCE4 repo have xfce4-notes?
I installed Xfce; but after noticing that xfce4-notes apparently didn't install, I went to install it myself, and discovered that the repo doesn't have it. Why not?
Apparently there is more than one Debian-based distro that can't or won't use xfce4-notes. Last time I tried Devuan, I found that I can't have xfce4-notes there either. If I recall, the devs told me on the forum that it would have broken something or other in the distro. Does Q4OS have a similar problem?
#2 2024-05-05 17:44
Re: why doesn't our XFCE4 repo have xfce4-notes?
Q4OS is Debian-based and uses the same repositories. Look at available versions of xfce4-notes for Debian. You'll see that it is not available for Bullseye (10) and Bookworm (11). There is a hole between 9 and 12. I don't know why. I believe it's the reason why it is not available either for the corresponding versions of Q4OS, Gemini (4) and Aquarius (5).
#3 2024-05-05 18:13
lookheart_nohands
Got it, not a Q4OS problem but a Debian problem.
