#1 2024-05-03 12:22
Toshiba3000
Avoid apt update output “can’t solve…” errors
Check Wifi auto start! Q4oS has not automatic WiFi default connections when you install for first time, it must be configured editing Wifi connections and checking “Autostart”, clicking “Next” until the last window, then check connect and save.
If not, doing manually apt update will show errors like “can’t solve” or “files missing” every time you start Q4oS on your computer and upgrade manually, and not will be updated/upgraded.
Also, installing Automatic upgrades avoid manual upgrade just clicking on the menu bar when an explosive warning icon is shown when are updates/upgrades packages ready to install
