q4os gemini is istalled here besides Windows and some other ntfs partitions.
In konqueror, under the node "Storage Media" all those partitions are correctly shown, with their label-name, e.g. "Data".
right-click on the Data-Item -> properties: shows the properties - for sda5.
Now. it's possible to mount that partition easily by: right-click -> mount. Fine!
But how can i achieve the same from the command line?
me@flex:~\> sudo mount -r /media/Data
mount: /media/Data: can't find in /etc/fstab.
me@flex:~\> sudo mount -r /media/sda5
mount: /media/sda5: can't find in /etc/fstab.both do not work!
The minimal command is (using the parameters from your example)
$ sudo mount -t ntfs /dev/sda5 /media/DataNote that the mount command has several options you might need to use to fit your needs (read-only, read-write, ...).
You can also have your partition mounted automatically, but you'll need first to sudo edit your /etc/fstab file (you didn't yet, whence the errors you got).
This is a vast question and I suggest you to read tutos available on the web.
Thanks hchiper,
this is nearly exactly what i tried some minutes ago, and it didn't work:
me@flex:~\> sudo mount -t ntfs -r /dev/sda5 /media/me/Data
ntfs-3g-mount: failed to access mountpoint /media/me/Data: file or directory not foundi chosed /media/me/Data because it's mounted there (like all other ntfs-partitions) when i mount it via konqueror.
Ironicallly, if i do mount /dev/sda5 (the Data-partition) via konqueror, guess what the mounting point is then:
me@flex:~\> mount -l
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
/dev/sda5 on /media/me/Data type fuseblk (ro,nosuid,nodev,noatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096,uhelper=udisks2) [Data]Exactly "/media/me/Data" - unbelievable!
Edit: And thanks again for the hint to "automatical mounting" - but first it should work the manual way
Just run in terminal:
$ mkdir /tmp/mountpoint/
$ sudo mount /dev/sda5 /tmp/mountpoint/
Thank you @q4osteam, that way it's possible to mount it.
Now, unfortunately all my (audacious) playlists rely on paths like file:///media/me/Data/Music/..../xy.mp3 so i ask: why shouldn't one use /media/me/Data as mounting point - may here arise any conflicts with the system?
Thanks in advance!
Edit: mabe it has to do with some difference between system:/media/sda3/media/ and /media ...
Optimal would be the possibility to have a partition-Symbol on the desktop (like it is represented in system:/media) but i see no possibility to create such with: right-Click: Create New... Link to device...
