#1 2024-04-11 11:43
thomastt23
Q40S new installation with Aquarius and full application
I have this installed on two different PCs,one works satisfactorily the other consistantly goes into sleep mode after only a short time and then i have to enter password for the system to show the desktop.NB I elected for automatic sign in during first installation but its obviously not working and I have been unable to change it using system settings.Can someone help me please,as i dont want to go through the rigmarole of uninstalling the OS and reinstalling it again!  Many thanks Michael
#2 2024-04-11 12:40
Re: Q40S new installation with Aquarius and full application
You give no information about your system. Please open a terminal, run 'inxi -Fxxx' and post the result.
while you are working or while it is idle? how long time?
You didn't find how to or the modification has no effect?
#3 2024-04-11 14:47
thomastt23
correct the auto log in did not work have tried again through terminal and it still doesnt work as I still have to open computer with a password seem like a bad installation?NB I have also set time to sleep to maximum amount,pushed apply setting and that doesnt make a scrap of difference either! ive also entered vt: 7 dm: SDDM Distro: Q4OS 5.4.1-n1 base: Debian GNU/Linux
    12 (bookworm)
Machine:
  Type: Desktop System: ASUS product: All Series v: N/A
    serial: <superuser required>
  Mobo: ASUSTeK model: AM1M-A v: Rev X.0x serial: <superuser required>
    BIOS: American Megatrends v: 1001 date: 11/25/2014
CPU:
  Info: quad core model: AMD Athlon 5350 APU with Radeon R3 bits: 64 type: MCP
    smt: <unsupported> arch: Jaguar rev: 1 cache: L1: 256 KiB L2: 2 MiB
  Speed (MHz): avg: 799 high: 800 min/max: 800/2050 boost: disabled cores:
    1: 800 2: 800 3: 798 4: 798 bogomips: 16369
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Graphics:
  Device-1: NVIDIA GT218 [GeForce 210] vendor: Pegatron driver: nouveau
    v: kernel arch: Tesla pcie: speed: 2.5 GT/s lanes: 4 ports: active: VGA-1
    empty: DVI-I-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:0a65 class-ID: 0300
    temp: 47.0 C
  Display: x11 server: X.Org v: 1.21.1.7 compositor: kwin_x11 driver: X:
    loaded: modesetting unloaded: fbdev,vesa dri: nouveau gpu: nouveau
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22")
    s-diag: 582mm (22.93")
  Monitor-1: VGA-1 model: Philips 230C serial: U3A0927000016 res: 1920x1080
    hz: 60 dpi: 96 size: 510x287mm (20.08x11.3") diag: 585mm (23") modes:
    max: 1920x1080 min: 720x400
  API: OpenGL v: 3.3 Mesa 22.3.6 renderer: NVA8 direct-render: Yes
Audio:
  Device-1: AMD FCH Azalia vendor: ASUSTeK AM1I-A driver: snd_hda_intel
    v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
  Device-2: NVIDIA High Definition Audio vendor: Pegatron
    driver: snd_hda_intel v: kernel pcie: speed: 2.5 GT/s lanes: 4
#4 2024-04-11 19:52
I don't know if you are using Plasma or Trinity DE (the beginning of the output of inxi is missing). If you are using Plasma, look both at "screen locking" and at "energy saving": each one has an option either to lock the screen or to suspend the session, requiring to type your password to return to your desktop.
#5 2024-04-12 10:37
thomastt23
i am using plasma,but have tried trinity but didnt like it,that much,plasma much better.btw i have tried both of those suggestions but they arent working as the screen keeps shutting dow and password is required.i have been thinking that the only difference wa between the two operating system installation was minimum installation and full installation..the minimum install is working as it should so maybe i should call quits on the full install and try minimum install?  michael
#6 2024-04-12 20:32
I have installed the "Basic" version and I don't have any similar problem, but it is Q4OS 4. No idea if the problem comes from choosing "Full" instead of "Minimal" installation.
