#1 2024-03-19 09:37
sub13
What iso / quelle iso
Good morning
I don't remember which version I used to install q4os I have 2 ISO
Either q4os-2.7-i386-instcd.r5.iso
Either q4os-3.14-i386-instcd.r4.iso
In the terminal I have
get-q4os-version
3.16.1-n1
Thanks you
Bonjour
Je ne rappelle quelle version j'ai utilisé pour installer q4os j'ai 2 Iso
Soit q4os-2.7-i386-instcd.r5.iso
Soit q4os-3.14-i386-instcd.r4.iso
Dans le terminal j'ai
get-q4os-version
3.16.1-n1
Merci
Asus Eee PC 1000H Atom N270 à 1.6 GHz ram 2go avec Q4os 3.16.1 centaurus
#2 2024-03-19 18:42
Re: What iso / quelle iso
If you are certain you used one of these only two iso, then it was 3.14 and you upgraded your system progressively to 3.16.
Q4OS doesn't upgrade from one major version (2.xx) to another one (3.xx).
#3 2024-03-21 10:59
sub13
Ok merci thanks you
