#1 2024-02-14 17:05
Spiky Friend
Update manager from the Q4 software center
Hello,
The update manager from the Q4 software center could not be uninstalled. I then uninstalled the package "q4os-updater".
I do not know if the error is known?
Desktop - Plasma. Machines - Dell Mobile Workstations m6800 and 7710
#2 2024-02-14 17:16
Re: Update manager from the Q4 software center
Please describe the procedure in more detail, so we can reproduce and investigate the issue. Error messages, etc ...
#3 2024-02-14 17:27
Spiky Friend
There is no error message, can't add anything to this other than what I've already written, except that I use plasma.
#4 2024-02-14 17:30
We don't understand what happened on your machine. Did you try to remove Update manager ? How exactly ? What did you see on the screen ?
#5 2024-02-14 17:49
Spiky Friend
I installed the update manager in Q4's own software center a few days ago to try it out.
Today an update came in and I let the update manager take care of it.
But because I'm used to doing my updates via the console and I couldn't see any advantage, I wanted to uninstall the Q4 Update Manager via the Q4 Software Center and found that the uninstall didn't work.
I then looked at the Q4 packages in synaptic and uninstalled "q4os-updater".
After that, the update manager was also uninstalled in Q4's own software center.
I'm sorry, but I can't describe it any more precisely than that.
#6 2024-02-14 17:55
Well, thanks for this info. Everything is clear, except the quotes below:
Spiky Friend wrote:
I wanted to uninstall the Q4 Update Manager via the Q4 Software Center ...
How exactly ?
Spiky Friend wrote:
... and found that the uninstall didn't work.
How did you recognize it didn't work ? Did you click to the "Uninstall" button ? What did happen next ? Did you see any window ? Or message or sign of the uninstall process ?
We are not able to reproduce the issue, uninstall process works fine here. Did anyone else noticed some similar issue ?
#7 2024-02-14 19:09
Spiky Friend
I have now done the installation again, all without a problem. But the uninstallation does not work (at least not via the Q4 Software Center).
After uninstalling, a window opens with uninstall now or cancel, of course I press uninstall, the window closes and where there was a green checkmark before is now a cross and the update manager is still installed. I can open the window (uninstall or cancel) again and again.
It can only be uninstalled if I uninstall the package "q4os-updater".
No idea how to attach pictures here, otherwise I could show more.
#8 2024-02-14 19:16
Spiky Friend
I have now uninstalled the "q4os-updater" package. Is that all right?
#9 2024-02-14 19:47
Yes, all right.
#10 2024-02-14 19:49
Click > Post reply link > Choose File > select an attachment up to 300kB in size
#11 2024-02-14 19:54
Spiky Friend wrote:
... a window opens with uninstall now or cancel, of course I press uninstall, the window closes
When you click "uninstall", non-interactive terminal window with uninstall process should open. Did it ?
It would be helpful, if you would run in terminal:
$ swcentre.exu
Initialize uninstall action of Update manager as described above
And post back the terminal output.
#12 2024-02-14 20:11
Spiky Friend
No, it does not open.
$ swcentre.exu
The Software-Center opens.
#13 2024-02-14 20:36
Yes. Now start the uninstall process and post back the terminal output.
#14 2024-02-14 22:09
Spiky Friend
Here is the terminal output.
$ swcentre.exu
[tdebuildsycoca] tdebuildsycoca running...
[2024/02/14 22:05:29.651] [dcopserver] DCOP Cleaning up dead connections.
konsole: Unbekannte Option 'title'.
#15 2024-02-15 10:19
Thanks, we will make a few checks and post back.
#16 2024-02-15 10:58
Please run in terminal and post back the output:
$ get-q4os-version
$ whereis konsole
$ konsole --hide-tabbar --hide-menubar --title test
#17 2024-02-15 11:01
Spiky Friend
get-q4os-version
5.4.1-n1
whereis konsole
konsole: /usr/bin/konsole /usr/share/konsole
#18 2024-02-15 11:19
Well, now run:
$ konsole --version
$ /usr/bin/konsole --version
$ /usr/bin/konsole --title test
and post the output
#19 2024-02-15 11:29
Spiky Friend
konsole --version
konsole 22.12.3
konsole 22.12.3
#20 2024-02-15 11:42
Konsole version seems to be correct. The clue is "--title" konsole argument. It doesn't work on your system, while we are not able to reproduce. It works fine here and konsole starts with the same "--title" argument. We have no idea what could be a culprit, however we will investigate more and post back later. Anyway, thanks for valuable reporting, so we can investigate.
#21 2024-02-15 11:45
One more question, have you another desktop environment alongside Plasma installed ?
It would be also helpful, if you would provide debug info file:
$ reportq4
as described here https://www.q4os.org/forum/viewtopic.php?id=3502
#22 2024-02-15 11:51
Spiky Friend
no only plasma
#23 2024-02-15 11:55
Spiky Friend
debug information
#24 2024-02-15 11:58
Spiky Friend
Has the debug information arrived?
#25 2024-02-15 12:11
Spiky Friend
I have noticed two things that I have not yet seen on any other system, I don't know if there is a connection.
1. this error occurred when adding the quick search in Synaptic:
Traceback (most recent call last):
  File "/usr/sbin/update-apt-xapian-index", line 61, in <module>
    import axi.indexer
  File "/usr/lib/python3/dist-packages/axi/indexer.py", line 39, in <module>
    from six.moves.urllib_parse import unquote
ModuleNotFoundError: No module named 'six'
what I have solved with "apt install python3-six"
2.Add drive to fstab:
mount -a
mount: (hint) your fstab has been modified, but systemd still uses
the old version; use 'systemctl daemon-reload' to reload.
Because the drive was mounted after a restart, I did not pursue it any further.
