#1 2024-01-04 23:37
antares
How to correct dll problem?
Is it possible to add missing dll without reinstallation of entire system?
see attachement
regards
#2 2024-01-05 06:50
Re: How to correct dll problem?
At a rough guess, you're trying to run an application in WINE.
It is possible that you have not installed wine32
So you need to:-
sudo dpkg --add-architecture i386
sudo apt update
sudo apt install wine32
The try running the application again.
I could be completely wrong - but who knows what you're trying to do as you haven't bothered to say.
#3 2024-01-06 14:06
nightflier
Try running the program using sudo.
https://forum.winehq.org/viewtopic.php?t=34517
#4 2024-01-07 18:33
"I do not recommend the "sudo" solution as it looks like an unsafe workaround for me.
Installing or playing games with wine/proton should usually not require admin privileges. Please remember that also games can be exploited to gain root level access to your computer."
Source here: https://forum.winehq.org/viewtopic.php? … 5b#p135985
@nightflier, please read the source topic more carefully and until the end, before giving an advice here.
#5 2024-01-13 14:47
nightflier
Will do.
