#1 2023-12-19 22:44
Coldfire
laptop crashing in Apps Installation and Desktop Profile
Hello everyone,
I have a problem with installing apps on my laptop since it always crashes and brings me to the login menu and shuts down all apps
This problem does also happen in the desktop profile installation it automatically just crashs
here's the result of inxi -F
System:
  Host: ColdComputer-OnFire Kernel: 6.1.0-16-amd64 arch: x86_64 bits: 64
    Desktop: KDE Plasma v: 5.27.5 Distro: Q4OS 5.4.1-n1
Machine:
  Type: Unknown System: Apple product: MacBook4,1 v: 1.0
    serial: <superuser required>
  Mobo: Apple model: Mac-F22788A9 v: PVT serial: <superuser required>
    UEFI: Apple v: MB41.88Z.00C1.B00.0802091535 date: 02/09/08
Battery:
  ID-1: BAT0 charge: 0% condition: 37.7/54.7 Wh (68.8%) volts: 3.6 min: 10.9
CPU:
  Info: dual core model: Intel Core2 Duo T8100 bits: 64 type: MCP cache:
    L2: 3 MiB
  Speed (MHz): avg: 798 min/max: 800/2100 cores: 1: 798 2: 798
Graphics:
  Device-1: Intel Mobile GM965/GL960 Integrated Graphics driver: i915
    v: kernel
  Display: x11 server: X.Org v: 1.21.1.7 driver: X: loaded: modesetting
    unloaded: fbdev,vesa dri: crocus gpu: i915 resolution: 1280x800~60Hz
  API: OpenGL v: 2.1 Mesa 22.3.6 renderer: Mesa Intel 965GM (CL)
Audio:
  Device-1: Intel 82801H HD Audio driver: snd_hda_intel
  API: ALSA v: k6.1.0-16-amd64 status: kernel-api
Network:
  Device-1: Broadcom BCM4321 802.11a/b/g/n driver: b43-pci-bridge
  Device-2: Marvell 88E8058 PCI-E Gigabit Ethernet driver: sky2
  IF: ens5 state: down mac: 00:23:32:9a:97:20
  IF-ID-1: wlan0 state: up mac: 00:23:12:08:43:59
Bluetooth:
  Device-1: Apple Bluetooth HCI type: USB driver: btusb
  Report: hciconfig ID: hci0 state: up address: 00:23:6C:BB:F8:13 bt-v: 1.2
Drives:
  Local Storage: total: 465.76 GiB used: 6.64 GiB (1.4%)
  ID-1: /dev/sda vendor: Western Digital model: WD5000LPLX-60ZNTT1
Partition:
  ID-1: / size: 450.85 GiB used: 6.63 GiB (1.5%) fs: ext4 dev: /dev/sda2
  ID-2: /boot/efi size: 299.4 MiB used: 5.8 MiB (2.0%) fs: vfat
    dev: /dev/sda1
Swap:
  ID-1: swap-1 type: partition size: 6.34 GiB used: 0 KiB (0.0%)
    dev: /dev/sda3
Sensors:
  System Temperatures: cpu: 48.0 C mobo: N/A
  Fan Speeds (RPM): N/A
Info:
  Processes: 161 Uptime: 1h 22m Memory: 2.88 GiB used: 1.87 GiB (64.8%)
  Shell: Bash inxi: 3.3.26
Thank you for listening
#2 2023-12-20 23:07
Coldfire
Re: laptop crashing in Apps Installation and Desktop Profile
Sorry for putting this topic here,
I couldn't put it in the bug tracking forum sad
#3 2024-01-03 11:02
NoMoreWindows
This seems to be the same issue as https://www.q4os.org/forum/viewtopic.php?id=4717
