#1 2023-12-11 16:23
KenUnix
Unix System V r3 3b2-700 available for Q4OS 64bit
I have a version of Unix that runs fine on Q4os 64bit. Yes real Unix.
3b2-700 was an AT&T mini-computer. The 3b2 700 running Unix System V.
Upon downloading the tar file simply untar (tar -xf) it into a directory
Change directory to that directory
Then type   ./unix
Unix will load and start. It will check the filesystems, set the date/time
and log you in as root.
When finished using Unix as root: cd / then shutdown -y -g0 then when single user mode
is started send Control-E then at sim> type exit.
There is source code under /usr/ken/usr.bin and /usr/src
There is a "guest" login with no password. Once up and running you will be able to
telnet into it using: telnet -e ^[ localhost 2323
If interested drop me a line and I will send you the link to it.
Enjoy
