#1 2023-11-09 11:02
Wifi connection troubleshooting
Trinity desktop:
Right click on the network manager icon in system tray > edit connections > select wireless connection > click edit connection button > go through all steps of the guide and enter proper values > until you get to the check box that says "Automatically Connect" > then click "Connect and Save".
Plasma, Trinity and other desktops:
Another way is to use terminal tool "nmtui", what is desktop environment independent. So run in any terminal:
$ nmtui
and setup your wifi
If you request a wifi related help, it would be appropriate to provide output of the following terminal command:
$ inxi -SMCGxn
Moreover, you should provide debug info as described here https://www.q4os.org/forum/viewtopic.php?id=3502
#2 2023-11-10 07:40
Re: Wifi connection troubleshooting
Might I suggest that for ANY wifi connection issue it is mandatory for the user to provide the output of inxi -SMCGxn before it is answered.
Without that one has no idea what sort of can of worms one is dealing with.
#3 2023-11-10 11:23
@bin
We have updated the OP, thanks.
#4 2023-12-03 01:15
kirkwood
I am new to Q4os so excuse me if I sound uninformed.  I am trying to set up aan Archer T2U plus usb adator for Wifi.  I cannot find out how to enable it.  The install disc does not execute at start up.  It may be set for Windows or Mac.  I know it can be configured for Mint linx or Ubuntu.  Any suggestions?  Thanks!
#5 2025-01-20 19:17
swarfendor437
ASUS X470-PRO, AMD Ryzen 7 1700X 8 Core, 16 Gb RAM, Asus GT1030 2 Gb DDR-5  Q4OS 5.7 (Aquarius)
#6 2025-01-21 23:47
Driver support for this device in Debian is a mixed bag, but take a look at this and read it all the way through,
https://docs.alfa.com.tw/Support/Linux/RTL8812AU/
To be honest youd be better off getting another device that has native Linux support as this product clearly states it doesnt support Linux.
#7 2025-02-04 18:16
VegaLinuxQ4
Noob's question...
At https://easylinuxtipsproject.blogspot.c … .html#ID10
"Speed up your wireless internet by disabling the WiFi power management"
Can it use in Q4OS TDE?
#8 2025-02-04 19:56
Use iwconfig and see whether your wifi chipset power management is on/ off or doesnt show anything. You really should post this question in a separate thread for better visibility. It should work but is it really necessary?
