Good morning,
I am a new user of this community and a new user in the Linux world. I have installed Q4OS with the aim of reusing a very old PC using Windows XP, both for professional curiosity and to give my kids a basic tool for their scholastic activities.
Here the basic info for the support request:
Hardware
IBM Thinkpad T30, Pentium 4, CPU 2.00 GHz, RAM 502 MB
Network controller Intersil Corp. ISL8474 Prism 2.5 – ISL3872 Prism 3
Ethernet controller Intel 82801 CAM (ICH3) PRO/100 VE (LOM)
Router
Fiber connection – covering protocols up to 802.11ax – WiFi6
I have installed the ISO q4os-5.2-i386-instcd.r2.iso, related to the Aquarius version, then installed via DVD created with ImgBurn.
The desktop environment is Trinity and the installation chosen was the Base installation.
Network Manager downloaded from Software Centre.
A brief description and steps to reproduce the issue.
Ethernet connection worked flawlessly. I started working on Network manager. No Wi-Fi network was available (including mine). With some difficulty I managed to get the wireless connection working setting it up as an hidden network
When I tried a network access with this connection, nothing is working (no web browser nor proprietary connections like Synaptic).
I really don’t know what could be missing (correct drivers or other Network Manager entries)
$ inxi –Fxxx and post back the terminal output.
System:
Host: q4os-desktop Kernel: 6.1.0-13-686-pae arch: i686 bits: 32
compiler: gcc v: 12.2.0 Desktop: Trinity v: R14.1.1 tk: Qt v: 3.5.0
info: kicker wm: Twin v: 3.0 vt: 7 dm: 1: TDM 2: XDM Distro: Q4OS 5.2.1-n1
base: Debian GNU/Linux 12 (bookworm)
Machine:
Type: Laptop System: IBM product: 2367NG8 v: N/A
serial: <superuser required> Chassis: type: 10 serial: <superuser required>
Mobo: IBM model: 2367NG8 serial: <superuser required> BIOS: IBM
v: 1IET71WW (2.10 ) date: 06/16/2006
Battery:
ID-1: BAT0 charge: 31.9 Wh (99.7%) condition: 32.0/47.5 Wh (67.4%)
volts: 12.2 min: 10.8 model: Panasonic IBM-02K7037 type: Li-ion serial: 2006
status: not charging
CPU:
Info: single core model: Mobile Intel Pentium 4 - M bits: 32
arch: Netburst Northwood rev: 7 cache: 512 KiB note: check
Speed (MHz): 1200 min/max: 1200/2000 core: 1: 1200 bogomips: 2392
Flags: ht pae sse sse2
Graphics:
Device-1: AMD RV200/M7 [Mobility Radeon 7500] vendor: IBM ThinkPad T30
driver: radeon v: kernel arch: Rage-7 ports: active: LVDS-1
empty: DVI-D-1,SVIDEO-1,VGA-1 bus-ID: 01:00.0 chip-ID: 1002:4c57
class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.7 driver: X: loaded: N/A
unloaded: fbdev,modesetting,vesa failed: radeon dri: swrast gpu: radeon
note: X driver n/a display-ID: :0 screens: 1
Screen-1: 0 s-res: 1024x768 s-dpi: 107 s-size: 243x182mm (9.57x7.17")
s-diag: 304mm (11.95")
Monitor-1: LVDS-1 mapped: LVDS res: 1024x768 hz: 60 size: N/A modes:
max: 1024x768 min: 640x480
API: OpenGL v: 4.5 Mesa 22.3.6 renderer: llvmpipe (LLVM 15.0.6 128 bits)
direct-render: Yes
Audio:
Device-1: Intel 82801CA/CAM AC97 Audio vendor: IBM ThinkPad T30
driver: snd_intel8x0 v: kernel bus-ID: 00:1f.5 chip-ID: 8086:2485
class-ID: 0401
API: ALSA v: k6.1.0-13-686-pae status: kernel-api
Network:
Device-1: Intersil ISL3874 [Prism 2.5]/ISL3872 3] vendor: Intel Wireless
802.11b MiniPCI driver: hostap_pci v: kernel port: N/A bus-ID: 02:02.0
chip-ID: 1260:3873 class-ID: 0280
IF: enp2s2 state: up speed: N/A duplex: N/A mac: 00:05:3c:08:a3:cc
Device-2: Intel 82801CAM PRO/100 VE Ethernet vendor: IBM ThinkPad A/T/X
Series driver: e100 v: kernel port: 8000 bus-ID: 02:08.0
chip-ID: 8086:1031 class-ID: 0200
IF: enp2s8 state: down mac: 00:09:6b:93:01:e3
IF-ID-1: wifi0 state: dormant speed: N/A duplex: N/A
Drives:
Local Storage: total: 18.63 GiB used: 5.2 GiB (27.9%)
ID-1: /dev/sda vendor: Hitachi model: IC25N020ATCS04-0 size: 18.63 GiB
speed: <unknown> type: N/A serial: CSH206D9GZE5TF rev: A71A scheme: MBR
Partition:
ID-1: / size: 17.68 GiB used: 5.2 GiB (29.4%) fs: ext4 dev: /dev/sda1
Swap:
ID-1: swap-1 type: partition size: 510 MiB used: 4.3 MiB (0.8%) priority: -2
dev: /dev/sda5
Sensors:
System Temperatures: cpu: 45.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 0 fan-2: 0
Info:
Processes: 133 Uptime: 27m wakeups: 1 Memory: 490.7 MiB
used: 240.5 MiB (49.0%) Init: systemd v: 252 target: graphical (5)
default: graphical Compilers: N/A Packages: pm: dpkg pkgs: 1616 Shell: Bash
v: 5.2.15 running-in: konsole inxi: 3.3.26
To conclude, I don’t have the knowledge on Network Manager and on Linux/Debian commands to do further troubleshooting to get the information needed; it's a tough challenge trying to find help in this multifaceted world of distros/communities.
Therefore I would like to have your help to see if this problem is solvable or is it better to stop here as the HW is too old to be “saved”.
Many thanks in advance
Hi,
I’ve found this post within an Ubuntu forum (posted 3 months ago)
https://askubuntu.com/questions/790745/ … o-internet
… knowing how to address a non working internet connection may help as follows.
opening a terminal and see if you can ping or traceroute to google's public dns.
ping 8.8.8.8
mtr 8.8.8.8
If you get communication with Googl's public DNS then skip down to the last step on DNS.
If you're not getting a ping/traceroute to Goole's DNS then start by making sure your wireless adapter is getting IP information with the command.
ifconfig
output should have ip information listed for your wireless adapter something like...
wlan0 Link encap:Ethernet HWaddr 00:xx:xx:xx:xx:xx
inet addr:192.168.1.55 Bcast:192.168.1.255 Mask:255.255.255.0
next check to make sure you have a default route
route
output should have a route something like...
default 192.168.1.1 0.0.0.0 UG 0 0 0 wlan0
At this point you should be able to ping and/or traceroute to Google's public DNS "8.8.8.8". If not then call your Internet provider for additional help with your internet connection.
Now that we can ping google's public DNS we can be well assured that our internet is working. If you're still having problems then your computer is most likely not reaching a working DNS service. You can check your DNS servers with...
cat /etc/resolv.conf
You should also check the connection status in your network manager if you're using a desktop version of ubuntu. Once you have identified/set your DNS servers make sure you can ping them as well. If you can ping the DNS servers that you have set then the problem resides above the network layer in a firewall or application issue.
Here some questions:
Is this something applicable for this problem ?
Is this something applicable in this environment ?
Thanks for any help to move forward
We don't think these instructions would be applicable. We would recommend you to follow instructions here https://linuxhint.com/3-ways-to-connect … on-debian/ and post back.
OK, thanks. Will do asap
by the way, how to attach a picture?
Sorry and thanks
Your account has been promoted, so you can now post links and attach files up to 300kB in size.
Initial notes:
The connection on my network that I’ve got using Network Manager was achieved using the "Hidden Network" option as it is not visible for this laptop.
Network with iwconfig – commands executed with connection “on”
sudo iwconfig
lo no wireless extensions.
enp2s8 no wireless extensions.
wifi0 IEEE 802.11b ESSID:"iliadbox-******"
Mode:Ad-Hoc Frequency:2.462 GHz Cell: 02:05:A1:16:A3:CC
Bit Rate:2 Mb/s
Retry short limit:8 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
enp2s2 IEEE 802.11b ESSID:"iliadbox-******"
Bit Rate:2 Mb/s
Encryption key:off
Link Quality=25/70 Signal level=-53 dBm Noise level=-79 dBm
Rx invalid nwid:0 Rx invalid crypt:184 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:620 Missed beacon:0
sudo iwlist scan
franco@q4os-desktop:~$ sudo iwlist enp2s2 scan
enp2s2 No scan results
franco@q4os-desktop:~$ sudo iwlist wifi0 scan
wifi0 No scan results
Network with nmcli – commands executed with connection “off”
franco@q4os-desktop:~$ nmcli d wifi connect iliadbox-****** password ******
Errore: rete con SSID «iliadbox-******» non trovata. (meaning not found)
Dont’ know if was correct, but I’ve tried also:
franco@q4os-desktop:~$ nmcli d wifi connect iliadbox-****** password ****** hidden yes
And also
franco@q4os-desktop:~$ nmcli d wifi connect iliadbox-****** password ****** ifname enp2s2 hidden yes
Network with nmtui – commands executed with connection “off”
If I select “Activate a connection”, I’ve got only the Ethernet connection and no wireless network visible
if I select “Edit a connection”, I’m able to see the one created in Network Manager
(see pic 04)
I’ll wait for your input to see if I need to dig more into this
Network with wpa_supplicant – executed with connection “off”
the wpasupplicat was already installed and gave me some errors; unistalled the reinstalled
the following command was executed with no errors
wpa_passphrase iliadbox-****** ****** | sudo tee /etc/wpa_supplicant.conf
network={
ssid="iliadbox-******"
#psk="******"
psk=******
franco@q4os-desktop:~$ sudo wpa_supplicant -c /etc/wpa_supplicant.conf -i enp2s2
Successfully initialized wpa_supplicant
nl80211: Driver does not support authentication/association or connect commands
nl80211: deinit ifname=enp2s2 disabled_11b_rates=0
enp2s2: Failed to initialize driver interface
enp2s2: CTRL-EVENT-DSCP-POLICY clear_all
Thanks a lot; let me know what I can do more
looking forward for a feedback
Good day,
Any hint or suggestions ?
Thanks a lot
Some points that retained my attention:
In your initial post you wrote (6th paragraph): "no web browser".
Do you mean you don't have a web browser installed? If that is the problem you could install Firefox from Q4OS Software Centre.
In the output of $ sudo iwconfig, I read
Mode:Ad-Hoc ...
although on my wifi, Mode is "Managed", not "Ad-Hoc"
In your screenshot, there is no bar-graph showing the WiFi signal level...?
More considerations:
- if there is a switch on the side of your laptop to set WiFi on/off, is it on?
- you could install rfkill ($ sudo apt install rfkill) and run it ($ sudo rfkill) to see the status of your wireless devices.
Hi hchiper
First of all, thanks for your comment; I was starting to feel too alone :-)
Coming to your points:
1. the web browser is correctly installed. The meaning of my point is that, although I see the connection to the wifi network, when I open the browser (Konqueror) and try to reach any site (e.g. Google) the message I receive is:
"An error occurred while loading https://google.com: Host www.google.com unknown"
Likewise, if I test the connection with Synaptic, the message I get is:
"W: Error downloading http://q4os.org/package name. Could not resolve "q4os.org"
2. I will test the "Managed" parameter instead of "Ad-hoc" and I'll post the result
3. Signal strength is good (3 bars)
4. There is no mechanical switch, just a sw configuration that is always enabled for "Enable Network Features" and "Enable Wi-Fi"
5. I will definitely do this test too and will post the result as soon as possible
Thanks again
Cheers
I had the chance to do the two steps
Wi-Fi Configuration
I have only 3 possibilities to choose from:
Client
Hotspot
Ad-Hoc
Client is simply not working and no message is issued
Hotspot is not working and the following message is issued:
Connection “Iliadbox” is not available on device enp2s2 because profile is not compatible with device (the device does not support Access Point mode)
The only connection working is when I use the “Ad-Hoc” mode
Regarding rfkill, I’ve installed it using Synaptic; I’ve got version 2.38.1-5+b1 (latest).
When I tried to run the command “sudo rfkill” in terminal (Konsole) I have no output whatsoever. If I simply run “rfkill” I got the following message
“bash: rfkill: command not found”
Thanks again
rfkill is available only for the "superuser", so it is normal that, without sudo, you get "command not found".
What is strange is that sudo rfkill lists nothing, just as if no WiFi adapter is found on your system. No idea what the problem can be.
Except maybe a bad configuration as a consequence of several tries. Maybe you could boot from a live CD, watching carefully if you see a warning about WiFi, and check if your WiFi works. If it doesn't work either, maybe a driver or hardware problem, but I fear I can't help further.
Hi hchiper
I appreciated your help, so thanks a lot.
This has been an issue with the T30 for a few years now.
Just get a USB wifi dongle and have done with it.
https://www.amazon.co.uk/gp/product/B008FZO1A2 works out of the box with linux.
Don't know which country you're in but you may find the equivalent.
Hi bin,
Thanks for the feedback; I'll try to get an USB dongle, which make sense.
Just for my personal knowledge: when you buy one of these dongles (for the moment I haven't found the model you indicated) is Q4OS able to detect a new peripheral on a USB port and download or propose the drivers necessary for it ?
Thanks again
Cheers
Hi bin,
I have got a Wi-Fi adapter from a friend. Using an Ethernet connection, here what I did step by step:
1. Booted the PC with the wifi adapter in the USB port
2. Checked the adapter name using the "System Info" program (RTL88x2bu from Realtek)
3. Googled "Wifi USB adapter RTL88x2bu". Found a discussion on a Debian forum.
What I did then are the following steps:
1. Install the packages git and dkms, that were missing on my installation.
2. Run the following commands in a terminal:
git clone https://github.com/cilynx/rtl88x2bu
cd rtl88x2bu
sudo dkms install $PWD
sudo modprobe 88x2bu
The last command was quite long, but went ok.
Rebooted the pc and did some test without the Ethernet connection.
As a result, I was able to see all the wifi network around me, including mine.
The final configuration was simple and direct. Just needed to insert the pwd.
Many thanks for putting me on the right path.
Hope that this should be helpful for newcomers like me (with a very old hw like mine) in the Linux environment.
Cheers.
I've tried to change the status of this post to "solved" but can't find what to do.
Edit the original post and modify topic subject.
