#1 2023-10-31 13:48
ThinkPad_Jan
Q4OS trinity randomly desn't see drives plugged into USB
When I connect some usb drive to the computer it sometimes (rarely) doesn't read it (doesn't see it at all) on a particular port, but after reconnecting it on a different port it does, although lately it doesn't see a healthy card connected to the sd port despite several attempts to remove and put it back in. I'm using a Thinkpad t470
Comp: ThinkPad T470, Intel Core i5-6300 2,4>3GHz, 16gb RAM, Intel Skylake GT2 [HD Graphics 520], Q4OS mit Trinity, Windows 10
#2 2023-11-01 09:16
Re: Q4OS trinity randomly desn't see drives plugged into USB
Slot(s) or device(s) with loose or dirty connectors?
#3 2023-11-01 11:19
ThinkPad_Jan
But when i plug, for example, other card or plug this card into Win 11 comp. it works
#4 2023-11-01 11:25
Connect your USB drive, and run in Konsole command lsusb. It will show all connected USB devices (including your mouse if you use it on your notebook). If your USB drive is not shown, then it is probably a hardware issue. Also, post here the output of lsusb command.
#5 2023-11-01 11:28
ThinkPad_Jan
The same thing happens when i plug my MP3 player (formatted as fat16) (card about which i was talking about earlier is formatted as fat32), it sometimes don't see it, then i must unplug it and plug to other USB port
#6 2023-11-01 11:34
ThinkPad_Jan
Bus 002 Device 002: ID 0bda:0316 Realtek Semiconductor Corp. Card Reader
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 04f2:b5ab Chicony Electronics Co., Ltd Integrated Camera
Bus 001 Device 002: ID 045e:07fd Microsoft Corp. Nano Transceiver 1.1
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
(sorry for message under yours i post it too soon)
#7 2023-11-02 11:06
You could try running
udevadm monitor
and see if anything shows up when plugging/unplugging usb devices, sometimes it can show useful information. If you plug in a usb device and it doesn't display anything then I would suspect a dodgy connector either on the machine side or the device itself. Make sure usb port and usb device are clean,
P.s. when running the above command press Ctrl+C to end monitoring.
#8 2023-11-14 11:36
ThinkPad_Jan
I reinstall the kernel and it works. The problem lies in "safe unplugging" in Trinity. Drivers unplugged with this method are usually not recognized until you repair them with Windows.
