#1 2023-10-22 15:29
naranja
[SOLVED]Not install from Q4OS software Centre/No update from Update M
Hi.
I am using Q4OS 32bits.
I want to install Synaptic and the system does not let me do it. I have the Update Manager installed and I realised that and I do not receive any update from about two weeks there used to be one or two updates a week. Any help? Thanks in advaced.
>>The software Center Show me 13 packege ONLY when normally shows 52.
>>The problem started from when I installed Balena-Etcher from OTHERS Q4OS APPS link, I could not uninstalled and the system gave me this errors.
UNINSTALLING FROM KONSOLE
adminq@q4os-desktop:~$ sudo apt-get install synaptic
E: Conflicting values set for option Signed-By regarding source https://dl.cloudsmith.io/public/balena/ … eb/debian/ bookworm: /usr/share/keyrings/balena-etcher-archive-keyring.gpg != /usr/share/keyrings/q4a-etcher.gpg
E: The source lists could not be read.
FROM PACKAGE CENTER
The package system is not consistent ...
Trying to recover the integrity of APT ...
E: Unable to read source lists.
E: Conflicting values set for option Signed-By regarding source https://dl.cloudsmith.io/public/balena/ … eb/debian/ bookworm: /usr/share/keyrings/balena-etcher-etcher-archive-keyring.gpg != /usr/share/keyrings/q4a-etcher.gpg
E: Could not read source lists.
Package system still not consistent, cancelling the installation ..
#2 2023-10-22 16:08
Re: [SOLVED]Not install from Q4OS software Centre/No update from Update M
Please post error messages and more detailed description of the issue.
#3 2023-10-23 18:32
naranja
Hi.
Q4OS team, thank you to try to help me. I have answered you above.
#4 2023-10-23 18:40
Please note, Balena Etcher installer is considered as a testing one. Run command in terminal and post its output:
$ ls -l /etc/apt/sources.list.d/
#5 2023-10-24 20:20
naranja
Hi.
Q4OS, here is. Please, write me any command I have to do. Thank you in advance.
adminq@q4os-desktop:~$ ls -l /etc/apt/sources.list.d/
total 24
-rw-r--r-- 1 root root  243 oct  1 20:40 10_q4os.list
-rw-r--r-- 1 root root  245 oct  1 20:40 12_qtde.list
-rw-r--r-- 1 root root 1219 oct  1 20:40 20_debian.list
-rw-r--r-- 1 root root  375 oct  1 20:40 30_debian_backports.list
-rw-r--r-- 1 root root  456 oct 22 14:32 balena-etcher.list
-rw-r--r-- 1 root root  122 sep 21 13:13 dvpck_q4os-etcher.list
#6 2023-10-24 21:08
Well, you need to edit the file:
/etc/apt/sources.list.d/dvpck_q4os-etcher.list
and comment out line:
deb [signed-by=/usr/share/keyrings/q4a-etcher.gpg] https://dl.cloudsmith.io/public/balena/etcher/deb/debian bookworm main
so it will look like this:
#deb [signed-by=/usr/share/keyrings/q4a-etcher.gpg] https://dl.cloudsmith.io/public/balena/etcher/deb/debian bookworm main
Afterwards run in terminal:
$ sudo apt update
and post back the result. Your system should be fixed now.
In addition post the output of command:
$ cat /etc/apt/sources.list.d/balena-etcher.list
#7 2023-10-24 21:32
We can also see you have defined a redundant repository "/etc/apt/sources.list.d/balena-etcher.list" what causes conflicts with other system repositories. Do you know, how did it emerge in your system ?
#8 2023-10-25 18:56
naranja
Hi.
Q4OS. Please, tell me all the steps one by one because that kind of steps is out of my knowledges. One by one, please.
#9 2023-10-26 08:36
naranja wrote:
...tell me all the steps one by one because that kind of steps is out of my knowledges. One by one, please.
1.Run in terminal:
$ sudo nano /etc/apt/sources.list.d/dvpck_q4os-etcher.list
2.Change line:
3. Save with ctrl+O
4.Run in terminal:
$ sudo apt update
#10 2023-10-26 18:21
naranja
[SOLVED] I GOT IT.
Thank you very much Q4OS Team. Now I have Balena-Etcher installed and the Software Center come back "out the box" like new. Thank you very much.
#11 2023-10-28 14:26
naranja
I ANSWER:
No, I don't know it. Could you tell me how do it?
#12 2023-10-28 18:10
That .list has been created, or at least modified for the last time, less than 1 hour before your initial post in this thread. Also, you had to give your password at that  moment. Does this help you to remember if you followed a tutorial to install Etcher?
Unfortunately, I have not enough knowledge to know if it is safe to just delete it + sudo apt update.
#13 2023-10-29 15:12
naranja
Hi HChiper:
Thank you to try to help me. The answer at your question:
No. I didn't follow any tutorial to install Balena-etcher. I downloaded it from a link of "others apps of Q4OS" that you can find in this forum. I installed like any other app, directly.
I'm waiting for Q4OS Team or, if you can, to fix the other question that saw and tell me Q4OS Team about redundant repository.
#14 2023-11-06 22:04
I probably missed "others apps of Q4OS" in this forum; do you have a link?
The safe ways to install apps are using Q4OS Software Centre or using Q4OS repositories via "$ sudo apt install <package>". Other install scripts for "expereimental" apps are also available in Q4OS' sourceforge website. Here, "safe" means avoiding conflicts problems like the one you are facing, and other ones.
