Hello,
I have installed Q4OS 5.2 on my old laptop.
In Synaptic, when I click on the button "Reload", I receive systematically an error message (it is in French on my machine but it is about of) :
Unable to download all the index files
The repository is no more available.
Unable to download http://q4os.org/qtderepo/dists/bookworm/InRelease
The file is not valid, "NOSPLIT" has been received.
The repository http://q4os.org/qtderepo is no more signed. The updates from such a repository can't be done securely and are deactivated by default.
It is also the same error for the repository http://q4os.org/qextrepo.
What can I do to solve this issue ?
Patrick
Laptop DELL Latitude D610 : CPU Pentium M 32 bits / RAM 2 GB / SSD 256 GB - Q4OS Aquarius
We are not able to reproduce the issue. This type of issues could occur, if you have not time synchronized. First, check your time and date is set correctly and try the action once again. In case of error persists, run in terminal:
$ LANG=C sudo apt update
and post the output here.
The date and time was correct.
I tried to reboot and I don't receive the error message again...
The update of the packages is now correctly done in Synaptic.
Don't understand what was the problem.
How can I change the subject with "Solved" ?
Thanks for the feedback.
Edit original post and change the topic subject.
Done, thanks.
