#1 2023-08-11 14:59
PRSoftware
Checking file system at startup
Hello
Every time I start my computer with the new version 5.2 Aquarius, I can see just after the message "Loading initial ramdisk" a full check of the file system on /dev/sda1.
This operation takes a long time on my computer.
Is it really necessary to do such check on every startup ?
Is it a way to disable it ?
Laptop DELL Latitude D610 : CPU Pentium M 32 bits / RAM 2 GB / SSD 256 GB - Q4OS Aquarius
#2 2023-08-11 21:39
Re: Checking file system at startup
Can you please post here the contents of your /etc/fstab file? You can do this by typing in terminal command
cat /etc/fstab, and post here the output.
#3 2023-08-13 08:48
PRSoftware
Here is the content of /etc/fstab (I replaced the IP address of the SSHFS mount)
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sda1 during installation
UUID=020c5311-7007-47b4-817e-1071d19e54fe /               ext4    errors=remount-ro 0       1
# swap was on /dev/sda5 during installation
UUID=a3461572-5e9c-4c89-b6f0-07a1c8fa468b none            swap    sw              0       0
/dev/sr0        /media/cdrom0   udf,iso9660 user,noauto     0       0
# Mount SSHFS Public
public@AAA.BBB.CCC.DDD:/home/Public/ /home/Public  fuse.sshfs   _netdev,x-systemd.automount,allow_other,uid=1000,gid=1000,noatime,port=22 0 0
#4 2023-08-13 17:47
In the string UUID=020c5311-7007-47b4-817e-1071d19e54fe /               ext4    errors=remount-ro 0       1, try to replace the digit 1 to 0 at the end of that string. It should disable filesystem check on boot.
You can read about it here: https://linuxconfig.org/how-fstab-works … e-on-linux
Do not change another values, because this can make your PC unbootable.
Strange, I also have Q4OS Aquarius 5.2 installed, but I have completely different /etc/fstab:
valentina@latitudee5450:~$ cat /etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a device; this may
# be used with UUID= as a more robust way to name devices that works even if
# disks are added and removed. See fstab(5).
UUID=68bead01-846f-44d3-a1be-3217886fb3e7 swap           swap    defaults 0 0
UUID=2c6e1994-5b32-43a5-93a6-603d5740769d /              ext4    defaults,noatime 0 1
tmpfs                                     /tmp           tmpfs   defaults,mode=1777 0 0
#5 2023-08-13 18:04
PRSoftware
Unfortunately, the modification of the last field in the fstab for the main disk has no effect on the check at startup.
#6 2023-08-14 06:50
You might just have a look at /etc/default/grub and see if it contains
GRUB_CMDLINE_LINUX_DEFAULT="quiet fsck.mode=force"
or any other line contains the fsck.mode=force argument.
Alternatively consider that you have a bad disk and/or a problem on shutdown which means the system is self checking as it is supposed to do.
Install and run gsmartcontrol and that will help determine if the disk is bad.
#7 2023-08-14 09:45
PRSoftware
There is not any line containing "fsck" in /etc/default/grub.
Here is the export of the gsmartcontrol command :
smartctl 8.3 2022-02-28 r5338 [i686-linux-6.1.0-10-686-pae] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model:     SH00M256GB
Serial Number:    YMA2106300148
Firmware Version: V1103A4P
User Capacity:    256,060,514,304 bytes [256 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Form Factor:      mSATA
TRIM Command:     Available
Device is:        Not in smartctl database 7.3/5319
ATA Version is:   ACS-4 (minor revision not indicated)
SATA Version is:  SATA 3.2, 3.0 Gb/s
Local Time is:    Mon Aug 14 10:34:14 2023 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is:   Unavailable
APM level is:     254 (maximum performance)
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, frozen [SEC2]
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00)	Offline data collection activity
					was never started.
					Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					without error or no self-test has ever
					been run.
Total time to complete Offline
data collection: 		(  120) seconds.
capabilities: 			 (0x11) SMART execute Offline immediate.
					No Auto Offline data collection support.
					Suspend Offline collection upon new
					command.
					No Offline surface scan supported.
					Self-test supported.
					No Conveyance Self-test supported.
					No Selective Self-test supported.
SMART capabilities:            (0x0002)	Does not save SMART data before
					entering power-saving mode.
					Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 (  10) minutes.
SCT capabilities: 	       (0x0001)	SCT Status supported.
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     -O--CK   100   100   050    -    0
  5 Reallocated_Sector_Ct   -O--CK   100   100   050    -    0
  9 Power_On_Hours          -O--CK   100   100   050    -    1
 12 Power_Cycle_Count       -O--CK   100   100   050    -    16
160 Unknown_Attribute       -O--CK   100   100   050    -    0
161 Unknown_Attribute       PO--CK   100   100   050    -    100
163 Unknown_Attribute       -O--CK   100   100   050    -    6
164 Unknown_Attribute       -O--CK   100   100   050    -    0
165 Unknown_Attribute       -O--CK   100   100   050    -    0
166 Unknown_Attribute       -O--CK   100   100   050    -    0
167 Unknown_Attribute       -O--CK   100   100   050    -    0
168 Unknown_Attribute       -O--CK   100   100   050    -    5050
169 Unknown_Attribute       -O--CK   100   100   050    -    100
175 Program_Fail_Count_Chip -O--CK   100   100   050    -    0
176 Erase_Fail_Count_Chip   -O--CK   100   100   050    -    0
177 Wear_Leveling_Count     -O--CK   100   100   050    -    0
178 Used_Rsvd_Blk_Cnt_Chip  -O--CK   100   100   050    -    0
181 Program_Fail_Cnt_Total  -O--CK   100   100   050    -    0
182 Erase_Fail_Count_Total  -O--CK   100   100   050    -    0
192 Power-Off_Retract_Count -O--CK   100   100   050    -    15
194 Temperature_Celsius     -O---K   100   100   050    -    40
195 Hardware_ECC_Recovered  -O--CK   100   100   050    -    0
196 Reallocated_Event_Count -O--CK   100   100   050    -    0
197 Current_Pending_Sector  -O--CK   100   100   050    -    0
198 Offline_Uncorrectable   -O--CK   100   100   050    -    0
199 UDMA_CRC_Error_Count    -O--CK   100   100   050    -    0
232 Available_Reservd_Space -O--CK   100   100   050    -    100
241 Total_LBAs_Written      ----CK   100   100   050    -    784
242 Total_LBAs_Read         ----CK   100   100   050    -    913
245 Unknown_Attribute       -O--CK   100   100   050    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      1  Comprehensive SMART error log
0x03       GPL     R/O      1  Ext. Comprehensive SMART error log
0x04       GPL,SL  R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x24       GPL     R/O     88  Current Device Internal Status Data log
0x25       GPL     R/O     32  Saved Device Internal Status Data log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
Selective Self-tests/Logging not supported
SCT Status Version:                  3
SCT Version (vendor specific):       0 (0x0000)
Device State:                        Active (0)
Current Temperature:                    40 Celsius
Power Cycle Min/Max Temperature:     40/40 Celsius
Lifetime    Min/Max Temperature:     26/40 Celsius
Specified Max Operating Temperature:   100 Celsius
Under/Over Temperature Limit Count:   0/0
SCT Data Table command not supported
SCT Error Recovery Control command not supported
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4              16  ---  Lifetime Power-On Resets
0x01  0x010  4               1  ---  Power-on Hours
0x01  0x018  6        51422808  ---  Logical Sectors Written
0x01  0x020  6          130601  ---  Number of Write Commands
0x01  0x028  6        59857707  ---  Logical Sectors Read
0x01  0x030  6          270643  ---  Number of Read Commands
0x07  =====  =               =  ===  == Solid State Device Statistics (rev 1) ==
0x07  0x008  1               0  ---  Percentage Used Endurance Indicator
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  4            1  Command failed due to ICRC error
0x0002  4            0  R_ERR response for data FIS
0x0005  4            1  R_ERR response for non-data FIS
0x000a  4            1  Device-to-host register FISes sent due to a COMRESET
For information, it is a new SSD disk I installed recently because of the failure of the previous HDD after 18 years of work.
Do you see something wrong for this disk ?
#8 2023-08-14 10:08
If the SSD disk is new, than it should be OK. You have not purchased a cheap noname SSD, right? They can be faulty from factory.
Not sure, will it help, but please run cat /proc/mounts and post the content here.
#9 2023-08-14 11:06
PRSoftware
Here is the content of /proc/mounts :
sysfs /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0
proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0
udev /dev devtmpfs rw,nosuid,relatime,size=1004056k,nr_inodes=205114,mode=755 0 0
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0
tmpfs /run tmpfs rw,nosuid,nodev,noexec,relatime,size=205148k,mode=755 0 0
/dev/sda1 / ext4 rw,noatime,errors=remount-ro 0 0
securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0
tmpfs /dev/shm tmpfs rw,nosuid,nodev 0 0
tmpfs /run/lock tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k 0 0
cgroup2 /sys/fs/cgroup cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot 0 0
pstore /sys/fs/pstore pstore rw,nosuid,nodev,noexec,relatime 0 0
bpf /sys/fs/bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=14470 0 0
hugetlbfs /dev/hugepages hugetlbfs rw,relatime,pagesize=2M 0 0
mqueue /dev/mqueue mqueue rw,nosuid,nodev,noexec,relatime 0 0
debugfs /sys/kernel/debug debugfs rw,nosuid,nodev,noexec,relatime 0 0
tracefs /sys/kernel/tracing tracefs rw,nosuid,nodev,noexec,relatime 0 0
fusectl /sys/fs/fuse/connections fusectl rw,nosuid,nodev,noexec,relatime 0 0
configfs /sys/kernel/config configfs rw,nosuid,nodev,noexec,relatime 0 0
ramfs /run/credentials/systemd-sysusers.service ramfs ro,nosuid,nodev,noexec,relatime,mode=700 0 0
ramfs /run/credentials/systemd-sysctl.service ramfs ro,nosuid,nodev,noexec,relatime,mode=700 0 0
ramfs /run/credentials/systemd-tmpfiles-setup-dev.service ramfs ro,nosuid,nodev,noexec,relatime,mode=700 0 0
systemd-1 /home/Public autofs rw,relatime,fd=54,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=15156 0 0
systemd-1 /home/patrick/Maison autofs rw,relatime,fd=55,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=15161 0 0
binfmt_misc /proc/sys/fs/binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime 0 0
ramfs /run/credentials/systemd-tmpfiles-setup.service ramfs ro,nosuid,nodev,noexec,relatime,mode=700 0 0
sunrpc /run/rpc_pipefs rpc_pipefs rw,relatime 0 0
tmpfs /run/user/1000 tmpfs rw,nosuid,nodev,relatime,size=205148k,nr_inodes=51287,mode=700,uid=1000,gid=1000 0 0
#10 2023-08-16 15:36
Everything looks good there. Sorry, I have no more ideas how to disable this system check...
#11 2023-08-16 16:30
PRSoftware
Ok, thank you for the time you spent on my problem.
#12 2023-08-16 16:47
Senas Komunistas
Hello.
The command line option
fsck.mode=skip
can be used to skip the disk check when booting. The line
Checking disks: 0% complete
may still come up but fsck will not be run, nor will boot time be increased.
Add
fsck.mode=skip
to the linux line in
grub.cfg
just before quiet splash. It is recommended to add the command to grub.cfg by editing
/etc/default/grub
thus:
GRUB_CMDLINE_LINUX_DEFAULT="fsck.mode=skip quiet splash"
and then run
sudo update-grub
#13 2023-08-16 17:23
PRSoftware
Well done, guy: the "fsck.mode=skip" disables totally the file system checking at startup.
