#1 2023-07-29 22:43
Viggen66
[Upstream] SDDM bug Acccount Picture Missing
Dear All,
On Q4OS Plasma 5.2, whenever you insert an account picture on your account, it doesn't appear on SDDM Login, I guess it must miss some dependency, can anyone confirm this bug, and give a possible solution?
Thanks
Bug tracker entry: https://sourceforge.net/p/q4os/tickets/203/
#2 2023-07-29 23:43
Re: [Upstream] SDDM bug Acccount Picture Missing
We have been investigating around this bug and found out it's Debian upstream bug, as it's reproducible on vanilla Debian/Plasma system as well.
Reproduce on plain Debian: install Debian Bookworm from official Debian live media, and change the first user avatar. It's changed inside the user session, but SDDM doesn't show the changed avatar on the login screen as described by the OP.
A workaround for O4OS is to remove files:
$HOME/.face
$HOME/.face.icon
#3 2023-07-30 10:15
Viggen66
Dear Team,
It does work indeed, it was the only bug I have encounter, no big issue here, very easy fix, thanks.
Also I want to give congratulations for this operating system.
#4 2023-10-24 19:41
We have been investigating around this bug and found out it's clear upstream bug, as it's reproducible on vanilla Debian/Plasma system as well. We have updated the post above accordingly https://www.q4os.org/forum/viewtopic.ph … 049#p25049
#5 2025-09-20 08:40
Guptill71
Sometimes account pictures don’t appear if the image format isn’t supported or if the permissions on the image file are incorrect. Verifying the format and permissions could fix the problem.
