#1 2023-07-25 16:12
[Closed] Annoying confirmation window in CUPS
My system information is here: https://www.q4os.org/forum/viewtopic.ph … 004#p25004
When I launch Control Panel ---> Peripherals ---> Printers, in CUPS Configuration page I constantly have very annoying confirmation window, which appears every time I click on something in that page.
Please watch video in 720p quality setting:
https://drive.google.com/file/d/1txKHEp … drive_link
I do not have this annoying window if I launch Firefox, then type localhost:631 in address bar, and after that enter username and password in fields.
Workaround: Open your browser, type in the address bar localhost:631, then type your account username and root (sudo) password.
#2 2023-09-09 13:56
Re: [Closed] Annoying confirmation window in CUPS
We can confirm this issue. We consider it as Q4OS specific one and it will be addressed as soon as possible.
#3 2023-09-10 06:06
Or as I suggested https://www.q4os.org/forum/viewtopic.php?id=4420 dump the web localhost browser interface and use system-config-printer instead - almost every other linux distro does.
#4 2023-09-10 10:52
... dump the web localhost browser interface and use system-config-printer instead ...
Q4OS detects and uses system-config-printer automatically, if installed. So you only need to install it:
$ sudo apt install system-config-printer
The above is also a temporary workaround for this issue.
#5 2023-09-16 13:00
The fix is prepared and will be released within the new q4os-base package.
#6 2023-10-14 15:41
This bug is fixed in the current Aquarius 5.3 release, so closing this report.
