#1 2023-06-22 16:22
Q4OS Virtualbox sessions hanging on shutdown
This is something that has annoyed me on and off over recent years. It's not limited to Q4OS, but as it comes with virtualbox-guest-X11 and virtualbox-guest-utils pre-installed I thought this may be useful.
I have found that Q4OS, and other distros with the above VBox stuff installed often hang on shutdown the interminable time that they do with some cryptic message like 'A stop job is running for User Manager for UID 1000' or 'A stop job is running for session 1 of user'....
It turns out this is the vboxadd service hanging.
The solution is to check which version of Vbox you are running on your host, make sure you have the exact same version of virtualbox guest additions ISO image - for example my host is on Vbox 6.1.40_Debian r154048 so I make sure I have the corresponding Additions iso from https://www.virtualbox.org/wiki/Download_Old_Builds_6_1
Next check your kernel version
uname -r
- in my case with TDE testing it's 6.1.0-9-amd64
Then
sudo apt install linux-headers-6.1.0-9-amd64
Next
sudo apt remove virtualbox-guest-X11 virtualbox-guest-utils
Next
sudo apt install gcc perl make
Reboot
In Vbox host window for the VM click Devices>Insert Guest Additions CD Image>Open>Right click and Open Konsole so you have a terminal session in the root of the CD Image files.
sudo ./VBoxLinuxAdditions.run
Let it run.
After it has finished
sudo usermod -a -G vboxsf <yourusername>
Eject CD
Reboot.
You'll now have the Guest Additions and Host on the same vBox versions and it will no longer hang on shutdown.
#2 2023-06-23 12:11
Senas Komunistas
Re: Q4OS Virtualbox sessions hanging on shutdown
Hello. You can use KVM. KVM works great.
#3 2023-06-23 15:33
@bin
We are not sure about updates. If Debian kernel is updated along with regular Debian updates, are Virtualbox modules updated automatically ? If not so, the Virtualbox additions would stop to work as soon as rebooted to the new kernel. Would you know, how these Vbox additions take care about the updated kernel ?
#4 2023-06-23 16:18
Never had any problems with kernel updates. The main functionality which is sharing with the the host and full screen display seems to carry over. If I install a different kernel - as opposed to an update - then yes it does require re-installation of the Additions along with the relevant headers.
The point I'm making is more about making sure the Guest Additions and Host are both the same version of Virtualbox in order to prevent issues with the vboxadd service shut down on the guest system.
Obviously if the guest additions are bundled with the ISO then there's no way of guaranteeing it - and it may be unimportant for most people. It's just one of those little problems that annoy me as I never know if the shutdown hanging is a bug or just vbox. This way I can be sure.
#5 2023-06-23 16:21
I also use Quemu KVM as it's a bit faster especially with some old Windows qcows, but struggling with sharing with the host machine time after time is just too much hassle! smile
#6 2023-06-23 17:16
So it seems the Vbox additions modules as installed using procedure above are compatible across regular Debian kernel and Linux-headers updates.
#7 2023-06-24 07:38
That's correct.
So, for example:-
Fresh install of TDE 4.12.
Remove virtualbox-guest-X11 virtualbox-guest-utils (which also removes q4os-vboxgutils whatever that is)
Reboot
Install Guest Additions 6.1.40 = same as host.
Configure sharing etc
Reboot
Update/Upgrade which brings in a minor kernel update 5.10.0-22 > 5.10.0-23 plus headers.
Reboot
Sharing and screen continue as before.
Remove kernel 5.10.22
Reboot
Sharing etc still OK
From here on it gets a bit odd.
Install backports kernel 6.1.0-0.deb11.7-amd64
Reboot
Everything OK
Remove any 5.10.x kernels, headers and associated files and reboot
Everything OK
Now, on other Debian based distros I have found the last bit to be a bit inconsistent. Installing a much later kernel did cause problems with sharing and display with a beta release (not Q4OS) Bookworm base so in itself may have had other factors.
With Q4OS experience shows that the virtualbox additions settings survive both kernel updates and upgrades. I have had issues with Bookworm betas of other Debian based distros where this has not been the case.
Final point - Virtualbox stores the Virtualbox Guest Additions settings in the machine data. So, a different distro then installed in the same VM will inherit those settings once Virtualbox Guest Additions is installed (or if the distro ISO includes a version of Virtualbox Guest Additions)
#8 2023-06-24 08:41
Thanks for sharing this. We will look at a possibility to improve Q4OS Virtualbox support.
#9 2023-06-26 13:14
While apparently related, I reckon it isn't even remotely similar to the problem I reported a while back at https://www.q4os.org/forum/viewtopic.php?id=3925 and which is still present in my setups.
It's worth pointing it out once more, though, just in case someone figured a solution...
