#1 2023-05-28 23:39
Russell_T
My TDE it's very ugly
Greetings to all of the Q4OS team
I've been a regular Debian/Q4OS user since 2019 and I'm very satisfied.
I'm only experiencing a few minor issues since I needed to upgrade to Q4OS 4 earlier this year.
All non-Trinity apps are being displayed with a white window color instead of using the color defined by the current color scheme.
I think I really need help because my vision is sensitive to very light colors.
C:\home\russ> screenfetch ; neofetch
         _,met$$$$$gg.           russ@q4os-desktop
      ,g$$$$$$$$$$$$$$$P.        OS: Debian 11 bullseye
    ,g$$P""       """Y$$.".      Kernel: i686 Linux 5.10.0-23-686-pae
   ,$$P'              `$$$.      Uptime: 1h 29m
  ',$$P       ,ggs.     `$$b:    Packages: 1970
  `d$$'     ,$P"'   .    $$$     Shell: bash
   $$P      d$'     ,    $$P     Resolution: 1024x768
   $$:      $$.   -    ,d$$'     DE: Trinity R14.0.12
   $$\;      Y$b._   _,d$P'      WM: TWin
   Y$$.    `.`"Y$$$$P"'          WM Theme: 10_Windows2000
   `$$b      "-.__               GTK Theme: Adwaita [GTK3]
    `Y$$                         Disk: 9,3G / 76G (13%)
     `Y$$.                       CPU: Intel Core2 Duo E7400 @ 2x 2,792GHz
       `$$b.                     GPU: Mesa DRI Intel(R) G33 x86/MMX/SSE2
         `Y$$b.                  RAM: 2135MiB / 3018MiB
            `"Y$b._
    ,g$$$$$$$$$$$$$$$P.       -------------------
  ,g$$P"     """Y$$.".        OS: Debian GNU/Linux 11 (bullseye) i686
 ,$$P'              `$$$.     Kernel: 5.10.0-23-686-pae
',$$P       ,ggs.     `$$b:   Uptime: 1 hour, 29 mins
`d$$'     ,$P"'   .    $$$    Packages: 1989 (dpkg)
 $$P      d$'     ,    $$P    Shell: bash 5.1.4
 $$:      $$.   -    ,d$$'    Resolution: 1024x768
 $$;      Y$b._   _,d$P'      DE: Trinity R14.0.12
 Y$$.    `.`"Y$$$$P"'         WM: twin
 `$$b      "-.__              Theme: Q4OS01 [GTK2/3]
  `Y$$                        Terminal: konsole
   `Y$$.                      CPU: Intel Core 2 Duo E7400 (2) @ 2.792GH
     `$$b.                    GPU: Intel 82G33/G31 Express
       `Y$$b.                 Memory: 1868MiB / 3018MiB
          `"Y$b._
I'm a animal!
#2 2023-05-31 13:25
Re: My TDE it's very ugly
You could try to change TDE colors in system settings.
#3 2023-06-01 23:56
PeterLinu
I have a similar problem. I took my own photo of basically, green grass and blue sky at sunset with a reddish hue top left. I then created the pic as a desktop. Looks remarkably like an old version of Windows!
#4 2023-06-02 06:39
@Russell_T It is possible you have not unlocked the full set of tools for altering your configuration.
Open Konsole and
sudo kcmodules --unlock
then go back to Control Centre>Appearance.....
The controls and colours in TDE are highly configurable, sometimes getting GTK apps to look good can be a challenge. When choosing the colour scheme make sure the box at the bottom about all apps using your colours is ticked.
I suggest that the Plastik theme with Q40S standard colour scheme is a good place to start.
