#1 2023-05-13 16:12
allin
is there somewhere to check which desktop environment i have got
i downloaded live cd to check q4os few weeks backs
but got busy would few other things , and could not check it
now i dont remember what i have in my usb drive
so is there any way to find it out
#2 2023-05-13 22:13
Re: is there somewhere to check which desktop environment i have got
If the icon in the lower left corner looks like three dots and an ">" sign, you have the plasma desktop.
Anyway, if you are using Plasma, it is mentioned on the login screen.
Otherwise you are likely using TDE.
