Hello Q4OS members and experts,
In the Plasma desktop, which is great, i am not able to see wireless connections.
When i logoff and switch back to [default], i assume the trinity desktop, then the wireless connection is available, right below in the taskbar.
Question: Why is the wireless network not available in the plasma desktop, or do i have to install a widget or application to have this installed?
Thank you so much for all answers and hopefully solutions.
Br,Michael
note: My Q4OS version = 4.12.1-n1
Hello,
right click on the arrow in the dashboard, and choose configuration miniatures box, you can add the wireless connection to the dashboard , by editing the préferences in the submenu input.
https://i.imgur.com/erodlWa.png
F
Hello Fred, Thank you so much for the quick support, only i'am sorry, cause i don't understand.
If i go to the first link you post then i can download lightshot... i think this is not what you mean....
Can you help me a little bit more?
Because i cannot manage....
Thank you so much!
@note: if i click in the taskbar on the arrow on the right side, than i can choose enable all, it i do this, than still no wireless network options are available.
if you make a right-click with your mouse on the arrow on the right side , and a Alt + C you can access to the picture like in my attachment
(sorry for my bad english)
Hello Fred, thank you so much for your support and answers. I can access the page you attached, only in the list there is no option to show the wireless connection. i upload a screenshot of my settings in: ibb.co/jWXKncx or
In Trinity i can see the wireless connection (just like on windows, right below on the taskbar), but on plasma it is a not available. Also in the widget there is no option to add. I download the app LinSSID, but this one show only the available networks in graph, but no option to make a connection.
hmm, i am not allowed to post links :-(
"You are not allowed to post links", why i don't know
I think the applet you need to add to the thumbnail box in the systray configuration is : NETWORK
see attchment
Thanks for your support Fred! In the widgets i have, there is no Network option to choose. Only have network speed as an option to add. Also the network settings i have in my configuration menu don't give me any options to change the WiFi network, see below: I installed the laptop first with the trinity desktop. But when connecting to an external monitor i had some issues. Then i read about this and the solution is to change to the plasma desktop. So i did this and the monitor issues are solved. Also the plasma desktop is great. The only thing is that i can't see my wireless network connection since i switch. When i took my laptop to a hotel, i find out that the wireless connections are not available in plasma, so i had to switch back to trinity to configure the wireless settings. When i turn back to plasma the connection is then still available. So there is a way to manage, only strange that i don't have the wireless connection settings in plasma :-(
wait, i can see i can download the widget with the "Plasma Add-On Installer". I will try this. Thx!
not working well when i try to install the widget. They have 2 versions. both i download, but cannot see the same logo as you have in your display.
Error loading QML file: file:///home/******/.local/share/plasma/plasmoids/com.github.davide-sd.ipaddress/contents/ui/main.qml:371:31: Type FullRepresentation unavailable
file:///home/******/.local/share/plasma/plasmoids/com.github.davide-sd.ipaddress/contents/ui/FullRepresentation.qml:29:1: module "QtPositioning" is not installed
file:///home/******/.local/share/plasma/plasmoids/com.github.davide-sd.ipaddress/contents/ui/FullRepresentation.qml:28:1: module "QtLocation" is not installed
Will try again later after reboot.
When I tried in q4os on LXDE, I had issues because the TDE-network would not automatically start up on boot, so I had to manually add it to the list of start up applications. That is a process to do but I used an app called stacer to do it. You may also have to go into TDE-network manager and click enable wireless (under the option "deactivate connection"), under LXDE i had to do that every boot. I now stick to Trinity but I have customized it so it is not so ugly lol.
I am using a Dell d430 so we may run into similar issues and they may use similar components.
@Lotus123
Please provide a debug info for us to be able to investigate the issue according to https://www.q4os.org/forum/viewtopic.php?id=3502
