#1 2021-10-11 08:52
Expand the disk, if you have installed via Windows installer
1. First make a backup.
2. Edit file "c:\Linux64\Debian11\install\preseed.cfg" with administrator permissions and modify the line:
wubiapp/disksize1 string <size_in_megabytes>
Change "size_in_megabytes" to a desired value. Make sure disk size doesn't exceed free disk space.
3. Run in Windows terminal:
fsutil file seteof c:\Linux64\Debian11\disks\root.disk <size_in_megabytes*1024*1024>
4. Remove the file "c:\linux64\debian11\install\stp_disk1expanded.stp".
5. Reboot to Linux, the disk will be resized upon boot.
#2 2022-10-09 10:07
bretsim
Re: Expand the disk, if you have installed via Windows installer
On a phone screen, that fsutil line just shows "size in megabytes". It resized my 20gb root.disk file to a 50k one.
It's only then that I realise the backup I had is actually a year old. Everything is lost, and because it was resized rather than deleted, there's nothing file recovery software can do. 2 years of use, and 1 year of it vanished in a single tap of the Enter key. The most annoying thing is I'm sure all the data is still sitting on the hard drive, but it's impossible to access. Sigh.
#3 2022-12-31 11:48
giuliohome
In win7 seteof command is not supported so I used trunk instead (see this answer).
(After reboot, resize2fs was extending the inode table as expected: everything went OK, it simply took a long time, since I added 100GB... Because I like Q4OS and Debian GNU/Linux 11 with KDE Plasma very much!)
#4 2023-05-03 03:50
Net_Nuttt
I am trying to increase the disk size.
I am running Windows 11.
The file preseed.cfg does not have debian-installer to edit. It has wubiapp/disksize1 string 20167
Is this the line I should edit?
Thanks
#5 2023-05-03 09:10
Is this the line I should edit? ...
Yes, it is. The line has been changed in the recent installer revision, we are going to update the original instructions.
#6 2023-05-04 02:17
Net_Nuttt
Thanks for the update!
