#1 2016-02-28 13:42
cpcnw
Selective install of additional software
In software centre make each item so you can select that item, and create an install list, then perform an unattended download / install of all selected items.
#2 2016-03-05 22:10
Basil
Re: Selective install of additional software
Definitely desirable!
#3 2016-03-17 09:21
Totally agree, because when I install Full featured Desktop it automatically installs Google Chrome and Thunderbird. Then I need to uninstall those applications manually. Google Chrome because It is spying on users an collects and stores personal information, and Thunderbird because I simply do not need it.
Also now, after I add i386 architecture using sudo dpkg --add-architecture i386 when I use sudo apt-get update, I always got error message when apt tries to download google i386 package files.
Uninstallation of Google Chrome solved this problem.
UPD: It is better to add new desktop profile, which contains all software from Full featured Desktop and also offers selective install option.
#4 2016-03-17 10:03
Yes, we would like to follow this idea in later desktop profiler versions.
#5 2016-03-17 12:54
It will be fixed in the next Q4OS release.
