Hello I have a problem.
When I connect the usb memory to the computer I can't open any file... But when I copy those files to the hard drive I can open them without problems. What is happening? Somebody could help me?
I am using Q4OS Trinity
Thank you.
Hiyall,
I think you need to format your USB stick as ext4. Remember to back up the contents before!
Hiyall,
Don't format. NTFS/FAT32 is fine. I had also faced that problem with Gemini (Trinity), even during playing media through VLC. Can't remember how it got resolved.
This may well be the issue you are describing https://www.q4os.org/forum/viewtopic.php?id=3826
I thought this had been fixed....or maybe it's in the next version in Q4OS 5.......
In addition to not being able to open the files that I have on the usb stick, I can't change the name of these files, I can't delete them, I can't do anything,
Does anyone know the reason? Do I have to change some type of permission? Or what do I have to do?
Thank you
You have;
1. to copy/paste the data to somewhere safe.
2. Format the USB stick to ext4.
3. Copy/paste the data back on to the stick
4. Try 'reading it again
PS: if it's music files, many audio programs are only able to read/play the music if the files are on the computer and then sent to the audio software.
... Format the USB stick to ext4. ...
No, it's not good advice, don't do that. You should have read/write permissions on different regular filesystems. Try to check, if your USB device could have some write protection switch.
I have check it with another computer (with windows 10) and the usb stick runs ok, I can open all files whithout problems, so i don't know what is happening.
and that's why I gave my advice.
EDIT: See solution in post #16.
@ivandebcn
Insert the USB stick in and run in terminal:
$ sudo blkid
Post the output here.
/dev/sda1: UUID="93d9588d-5716-4f31-bf6c-dffbccf48adb" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="f65e86d9-01"
/dev/sda5: UUID="7c681bec-e94f-44bf-9f2e-1fedd215aaa7" TYPE="swap" PARTUUID="f65e86d9-05"
/dev/sdf1: LABEL_FATBOOT="TOSHIBA" LABEL="TOSHIBA" UUID="04AD-6276" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="40340a3b-01"
Does a popup window appear, when you insert the USB stick ? Would you post a screenshot ?
When i try to open files from usb stick:
And this:
It seems, you have encountered known Trinity bug https://www.q4os.org/forum/viewtopic.php?id=3826 as @bin mentioned above. It should be fixed in the new Trinity 14.1.0 version, what will be available in the upcoming Q4OS 5 Aquarius edition.
