#1 2023-04-18 01:36
PeterLinu
[SOLVED] q4os-4.11-x64-tde.r1.iso
Hiyall,
I had reason to re-install q4os. I thought I would try the 64-bit os as a VB guest on my Linux Mint 64-bit computer. On 5 occasions, it went through the install process however once completed, it showed me the live again!
I then installed the 32-bit version without issue.
What's the story?
#2 2023-04-18 06:20
Re: [SOLVED] q4os-4.11-x64-tde.r1.iso
With VirtualBox, what i have found with the 64 bit TDE iso is that when doing an install using the 'Live' option, it does not eject the the media at the end of the install. Have to shut down and eject from the VirtualBox control panel. This has been the case for as long as I can remember with TDE.
Haven't tried with the other install options as they do not interest me.
#3 2023-04-18 07:09
PeterLinu
thanx bin.
32-bit version works just fine.
