#1 2016-02-27 13:51
Jerome
Saving konsole schema
How do you save a new konsole schema? Having selected a new schema I click Settings/save as default  but it makes no difference; whenever I start a new session the schema has reverted back to the default "Linux Colours".
Thanks in advance for any help.
#2 2016-02-27 14:32
Jerome
Re: Saving konsole schema
Ok once again I've answered my own question. One way of doing it to use the command 'konsole --schema <schema_name>'.
#3 2016-02-27 22:47
Right mouse click on the konsole -> Settings -> Configure konsole -> Session tab -> set 'Schema' combobox to the preferred -> Ok -> Save -> Restart konsole
#4 2016-02-28 12:19
Jerome
Thanks q4osteam.
