#1 2023-03-22 20:38
just1acc
Can't write/paste in partitions
Q4OS Gemini Trinity.
Can't have permission to paste something/create new in partions, all partitions. Please guide.
#2 2023-03-23 07:33
Re: Can't write/paste in partitions
A little lacking in detail but let's see what we can do.
If you are in your /home location you have permissions to read/write in that user space as you own /home/username.
However you (as a user) cannot create anything new in /home because you do not have permission to do so.
Likewise you (as a user) cannot write/create in the / partition. (Generally speaking).
If you have a need to write/create outside /home/username you need to be using sudo to do so.
If this does not cover your question please provide an example of what you want to do.
#3 2023-03-23 15:38
just1acc
I am able to make file/folder in desktop (or may be in home). However it seems only view permission for other locations. Surprisingly in the partitions other than OS partitions. Even after deleting and re-creating through GParted.
Example:
1. Can't copy something in other partition (non-OS).
2. Create file/folder option isn't available.
P.S. Perdon my not well versed question. Apart from different Windows, I am only used to Linux Mint (Gnome 2 > Mate). Never used other Linux distros for more than 1-2 days (mostly *buntu based) until installation of Q4OS in an old Core2Duo laptop.
#4 2023-03-23 23:17
Where do you want to copy/create files or directories? Please give full details (which command line in the terminal or commands in another program).
A normal user is allowed to copy/create/modify/delete files or directories ONLY in its own directory, which is /user/<username>. It is a matter of security ans stability of the system.
One cannot copy/create files or directories in a common way directly into a partition; it has first to be formatted and mounted into the file system.
#5 2023-03-23 23:38
just1acc
I have two partitions. In one Q4OS installed. Other one kept for data.
I can't paste or create anything in that free partition. Definitely that is not "security". Locking down OS files is understandable.
Although, I have a feeling that the partition isn't being mounted with full read/write.
#6 2023-03-24 08:30
You can also attach a screenshot.
It could also be useful to know the output of these commands (in a terminal):
$ lsblk
$ ls -l <path-of-directory-where-you-want-to-write-into>
Sorry, but it is still unclear to me whether you want to write into a partition or into a directory; you seem to use the two terms interchangeably, but these are two completely different things. I guess you mean directories, but it's only a guess.
#7 2023-03-26 10:41
just1acc
There is no terminal involved. Just simple right click then paste or right click and create isn't available.
#8 2023-03-27 07:26
With your normal user account ANYWHERE outside your home folders that is what is supposed to happen.
As a user you do not have access rights to write to anywhere else.
Open Konsole
Prompt will be:-
username@machinename:~$
cd ..
It will now be:-
username@machinename:~/home$
sudo mkdir mydata
sudo chown -R username:username /home/mydata/
You can now do stuff in that folder.
#9 2023-03-29 16:02
just1acc
Tried to do that on whole partition (non-os), could not work. May be I am doing wrong. Anyway, its a spare/testing laptop, so I can live with that.
I have another machine with Windows 10 and Linux Mint 21.1 dual booted. Never faced such problem from Mint - in data/windows/NTFS/ext4 whatever it is.
