#1 2023-03-14 18:33
JTS
How to setup TDENetworkManager to connect to wiifi automaticly
Hi,
I am knew user. I am not able to find how to enable connection to the same wifi after any restart OS automaticly. Every knew session is writiten something like that: "wifi connection disabled". In my native Czech language is written "bezdrát zakázán". Every time it is nessery to change it to "wifi enabled" in my native language: "bezdrát povolen".   And as a next step to choose the same wifi, which was setup in the first session.
Thanks a  lot for any answers and have a nice time
#2 2023-03-15 07:19
Re: How to setup TDENetworkManager to connect to wiifi automaticly
Go through the connection wizard adding password as required - then 'Next' until you get to the check box that says Automatically Connect and then click Connect and Save.
#3 2023-12-19 08:01
kevin_maher
Thanks bin - I have the same issue and hadn't considered walking through the steps one Next button at a time.  Tried it now and it reconnected straight away after a reboot!
Cheers
Kevin
