#1 2023-03-05 08:39
kovach
disable kmix at startup [SOLVED]
Hi everybody!
how can i disable kmix at startup?
my old box cannot play sound.
#2 2023-03-05 11:01
Re: disable kmix at startup [SOLVED]
Run in terminal:
$ kwriteconfig --file "kcmartsrc" --group "Arts" --key "StartServer" "false"
$ kwriteconfig --file "knotifyrc" --group "StartProgress" --key "Arts Init" "false"
$ kwriteconfig --file "knotifyrc" --group "StartProgress" --key "Use Arts" "false"
Reboot
#3 2023-03-05 22:49
kovach
Thanks!
#4 2025-02-27 19:12
VegaLinuxQ4
Run in terminal:
Reboot
In TDE its just kill in task manager, while after reboot KMIX back to appear again in startup task manager & applet. How to disable KMIX startup & applet in TDE which it won't appear back again in next boot?
