#1 2023-02-24 05:19
PeterLinu
[SOLVED] Conky
Hiyall,
Completed conky attached.
#2 2023-02-24 09:33
Re: [SOLVED] Conky
Did you try and did something go wrong?
$ sudo apt install conky
Conky is available for both 32 bit and 64 bit. To check for your own system:
$ apt list conky
#3 2023-02-24 12:19
PeterLinu
Re: [SOLVED] Conky
It's very fixed and very ugly. Is there a way to modify it?
#4 2023-02-24 13:33
Re: [SOLVED] Conky
For example, see here.
Don't hesitate to use the search tool in this forum before asking.
#5 2023-02-24 18:37
Re: [SOLVED] Conky
The pkg you need to install is conky-all which supports transparency and stuff.
sudo apt install conky-all
#6 2023-03-06 23:00
PeterLinu
Re: [SOLVED] Conky
As soon as I saw this I knew there was more to it. "1. Download a conky theme."
Conky is nearly finished. It'll be on my desktop before the end of the day.
Thank you.
BTW, "Don't hesitate to use the search tool in this forum before asking." We Aussies are far more thick-skinned. You have my permission to be forthright!
#7 2023-03-09 07:46
ajeto
Re: [SOLVED] Conky
any images ?
#8 2023-03-09 07:56
PeterLinu
Re: [SOLVED] Conky
Non-Q4OS activity resulting in a slight delay. Watch this space.
#9 2023-03-15 01:07
PeterLinu
Re: [SOLVED] Conky
Hiyall,
How do I replace the default conky with my newly-completed conky?
