#1 2023-02-15 04:49
PeterLinu
[SOLVED] Screenshot2
Hiyall,
I couldn't find a SIMPLE screenshot application within Q4OS so I went 'outside' and with the terminal command: 'sudo apt-get install ksnip', I managed to install it. Once again, I want to put it on the task bar however it doesn't want to install.
Is there a NATIVE, SIMPLE screenshot app that will install on the task bar?
#2 2023-02-15 07:26
PeterLinu
Re: [SOLVED] Screenshot2
Persistence.
I finally managed to put ksnip on the taskbar. it was neither simple nor easy...but it's done.
I would still prefer a NATIVE & SIMPLE application.
#3 2023-02-15 09:12
If you are using Trinity desktop just use ksnapshot-trinity
#4 2023-02-15 12:11
PeterLinu
I played with ksnip a bit and it works for me. I'll leave it at that, thank you. This is not a major issue.
#5 2023-02-16 04:42
PeterLinu
Q4OS Team,
and where can I find ksnapshot-trinity?
#6 2023-02-16 05:24
PeterLinu
I actually found it myself! in synaptic. I prefer ksnip. Thanx anyway.
