#1 2023-02-13 23:10
PeterLinu
Updater [SOLVED]
Hiyall,
I'm really enjoying Q4OS. Very well-thought-out OS. I'm impressed.
I have it installed currently as a 'guest' in an Oracle VB. The host is Mint Cinnamon 21.1.
The installation is the smallest of the 3 as its final use will be on another laptop to play music in the lounge room ...and that's all!
I installed the 'updater' but can't find where/how to use it.
Any help would be appreciated.
#2 2023-02-14 08:12
Re: Updater [SOLVED]
If you are speaking of "Update manager" then, once installed, it checks automatically the repositories from time to time and suggests to upgrade when needed. In this case, an orange or red star or gear will appear in the tray (red for critical upgrades, orange for non critical ones, if I guess well). Left-click it to open the update manager to see a list of the proposed updates, and to accept or reject them. Or right-click it to configure.
#3 2023-02-14 08:17
PeterLinu
thank you hchiper.
