Use the following trick how see bottom of some windows, if they overrun bottom edge of the screen. Hold the right "Alt" key, click with mouse somewhere inside the window and drag the window out of screen border to get the bottom of the window visible.
See an additional tip for Plasma desktop https://www.q4os.org/forum/viewtopic.ph … 019#p24019
Nice one! Thanks for sharing! ![]()
I tried, but right Alt key didn't act as you described in my netbook.
Thus, lower part of some menus still remain hidden and I'm not able to click on OK button.
Paolo
The default for this on my system was the Meta (Window) key. In Plasma settings, it can be configured by:
1. right clicking title bar
2. choose more actions - configure window manager
3. choose window actions in left side menu
4. choose window actions tab
5. select desired settings under inner window, title bar and frame actions.
Thanks for the tip. Meta+left click worked out of the box for me (Q4OS 4.11 + Plasma).
OP updated
