I want to use the program onedriver to use my MS OneDrive in Q4OS.
How do I install that?
Linux is new for me.
Q4OS is installed in my Windows and run very fine.
Here is written, what you are looking for:
https://itsfoss.com/onedriver/
Or try to install this deb-file: https://launchpad.net/~jstaf/+archive/u … _amd64.deb
Thank you for good advise.
The program is installed and open the little window with the + in the corner.
I have chosen a map for the drive to mount MS OneDrive, but after that nothing happens.
The window to ad my MS account don't pop up.
What am I doing wrong?
Sorry - I am new on Linux!
If I remember correct, you need to create a folder in you home directory. Call this anything you like, I used "OneDriver"
After that in the OneDriver dialog, you click the + and navigate to that folder, select and then use the slider button to mount if it does not mount automatically
Oh yes, you also need to log into your Microsoft account
Thank you! very much. Now it works!!!
