#1 2022-12-20 17:09
GerardG
Installation sur disque externe USB
Bonjour,
Mon disque dur SSD est presque plein (11 Go libres). Puis-je installer Q4os sur un disque externe relié en USB ?
Je suis actuellement sous Windows 7
Merci d'avance
#2 2022-12-20 22:29
Re: Installation sur disque externe USB
Please use English in this forum (translate.google.com).
Regarding install on an USB key, this thread and this thread are of interest. The point is that to have Grub properly installed on the USB key you'll have to remove the internal disk before beginning the install.
#3 2022-12-21 07:57
GerardG
Thank you very much for your help.
Sorry for the use of French, I will be careful in the future.
I will follow your links and try to understand.
