#1 2022-12-15 13:19
photino
[SOLVED] Q4os live session does not open
Booting on  a USB key loaded with q4os-4.10-x64.r2.iso opens well the blue page with the two loading options :
      Live Media
      Q4OS  4  Gemini Live
      Q4OS  4  Gemini Live  (Failsafe) :
but none of these options has any effect, though the process seems to start since it indicates during a few seconds  :
Loading live /vmlinuz … ok
Loading live / initrd.img….
then back to the loading options.
Same behaviour with several different computers ; I specify that the integrity of the iso file has been verified with MD5..
Thanks for your help
#2 2022-12-15 14:06
Re: [SOLVED] Q4os live session does not open
Your .iso file can be good but maybe not your USB key. In that case I would recreate my bootable USB key or use another one.
#3 2022-12-19 17:41
photino
The problem was actually related to the USB key, it worked well with another one.
