#1 2022-09-18 20:57
nikos63
desktop profiler - install progress, stalled at language packages...
Hi!
A newbe at linux OS..
I have just installed the Q4OS Gemini, Trinity, 32bit for the most part, but I have been frozen at
desktop profiler - install progress, at language packages...a couple of hours now...
Should I stop the desktop profiler - install progress, and try back again...??
#2 2022-09-18 21:08
Re: desktop profiler - install progress, stalled at language packages...
Yes, please try to run Desktop profiler once again and post back.
#3 2022-09-19 16:11
nikos63
Ok, problem solved, after I run Desktop profiler once again! smile
Thank you for your quick response my friend!
