#1 2022-05-31 18:23
barkerg
Failed Downloads
I tried downloading the latest x64 versions of the Trinity live and install images but both failed around 100 and 70 MB. There doesn't appear to be a problem on my side since I was able to successfully download a 331 MB image from the Armbian website.
#2 2022-05-31 18:29
Re: Failed Downloads
What site do you download from ? Does anyone else struggle downloading Q4OS images ?
#3 2022-05-31 18:44
barkerg
It was from q4os.org/downloads1 which then eventually redirects to Sourceforge.
#4 2022-05-31 19:54
Make another try a few hours later and post back please.
#5 2022-05-31 23:53
barkerg
The installer file failed again about 10 minutes ago at 27.6 MB.
#6 2022-06-01 07:51
As a test, I just tried to download q4os-4.8-x64-instcd.r2.iso. At the beginning, the download was slow, but after some seconds the speed oscillated betweeen 2-5 Mb/s. Then, after 157 Mb the download stopped and Firefox interrupted it.
By chance, Firefox enables one to resume an interrupted download, which is what I did, and I could complete the download with the same range of speed. I checked the md5 sum and it is correct.
#7 2022-06-01 10:43
Thanks you both for the feedback. That seems to be some issue on SourceForge, anyway we will investigate it and try to make a resolution in cooperation with SourceForge.
#8 2022-06-01 12:52
I use the NetCologne mirror and it is working fine to UK - has OP tried a different mirror?
#9 2022-06-01 15:17
barkerg
It took me 7 restarts but I finally got the whole file downloaded. I didn't see any indication of mirror sites on the download page. Does someone have a list or url for these?
#10 2022-06-01 15:46
Go to https://sourceforge.net/projects/q4os/files/stable/
Select your chosen file
On the next screen Click Cancel for the default download
Click on Problems Downloading
Pick a different mirror from the list
#11 2022-06-01 16:05
barkerg
bin: Thanks for the info. I've never used that option in Sourceforge before. Usually I've seen a mirrors list on the OS's download page.
#12 2024-03-27 21:10
magnus
Download is broken at the moment. Sourceforge seems to do some kind of countdown to start a download, and next refreshed the page, and no download whatsoever. I have tired the "problems downloading" option and tested locations in Germany and Sweden but nothing is downloaded.Any alternative to Sourceforge please?
#13 2024-03-27 21:30
What browser and method do you use and what file do you try to download from Sourceforge ? You could also use Q4OS imager, see https://www.q4os.org/forum/viewtopic.php?id=4444 . Imager also downloads from Sourceforge, so we don't know, if it makes some difference.
Anyone else could confirm the issue ?
#14 2024-03-27 21:30
magnus
Ok, The download works now once I switched from a slow wifi dongle to another faster wifi hotspot.
