#1 2022-05-23 11:26
medianjoe
VirtualBox issue
I'm using Gemini with TDE and have installed VirtualBox from this link : https://sourceforge.net/projects/q4os/f … ntal_apps/
However, after setting up an environment for Windows 7, I get this error message:
The VirtualBox Linux kernel driver is either not loaded or not set up correctly. Please try setting it up again by executing
'/sbin/vboxconfig'
as root.
If your system has EFI Secure Boot enabled you may also need to sign the kernel modules (vboxdrv, vboxnetflt, vboxnetadp, vboxpci) before you can load them. Please see your Linux system's documentation for more information.
where: suplibOsInit what: 3 VERR_VM_DRIVER_NOT_INSTALLED (-1908) - The support driver is not installed. On linux, open returned ENOENT.
Never used VirtualBox before, but I just accepted the recommended settings.
Any help appreciated.
#2 2022-05-24 07:31
medianjoe
Re: VirtualBox issue
Never mind... I installed QEMU instead.
