#1 2021-11-21 07:01
Gemini Backports kernel install script error
Hi Devs
Just a quick note re the qinst-kernel-bpo script
It needs to be updated to work with bullseye - it still shows buster.
Thanks
#2 2022-03-25 08:44
moonoverhills
Re: Gemini Backports kernel install script error
the backports works perfect i even run the mxlinux backports on it no errors here.
#3 2022-03-25 12:28
Backports do work - this is an error in a Q4OS script that installs a backport kernel. The script tests for buster when it should be testing for bullseye.
#4 2022-04-10 21:08
Fixed, you only need to upgrade to Q4OS 4.8.
#5 2022-04-11 07:47
smile
