#1 2022-03-06 18:27
tw454
[Closed] install applications
Hi,
I went throgh the installation and ran the dektop profiler. I selected the basic package and XFCE as additional desktop environment. After the dektop had appeared, I tried to install more programs in the Software Centre from the welcome screen. But the Install button triggered this message:
"You have applied no dektop profile yet. (...) Please run Desktop Profiler tool to choose and apply a profile."
My question is: is there a way to fix this, or a different way to install more applications?
Thanks
installation: q4os-4.7-i386-instcd.r1
EDIT by Admin: This bug has been put at the official bug tracker https://sourceforge.net/p/q4os/tickets/179/
#2 2022-03-06 19:15
Re: [Closed] install applications
Please provide the debug info using "reportq4" command as described here https://www.q4os.org/forum/viewtopic.php?id=3502
#3 2022-03-06 19:31
tw454
Desktop environment: Xfce
Desktop software profile: Basic
The issue occurs whenever I try to install applications from the Software Centre.
qreport.tar.gz
#4 2022-03-06 19:48
We are now able to reproduce the issue. We will investigate and post back. Thanks for reproting.
EDIT:
Anyway, it's possible to use software centre from within Trinity or Plasma DE, but not from XFCE.
#5 2022-03-06 20:02
tw454
Thanks for the reply!
Can I change desktop environments without reinstalling the OS?
#6 2022-03-06 20:25
Yes, just select desired desktop environment on the login screen.
#7 2022-03-07 11:40
We have found the reason of this bug, it will be fixed in the next Q4OS release.
#8 2022-05-11 15:54
Fixed in Q4OS 4.8 release, closing this bug report.
