I'm using 3.15 version of this operative system, but I want to upgrade to newest version. Greetings.
.....then you want Gemini 4.7
If you're on 3.15 now then just install new from scratch. Provided your /home is on a separate partition it will work fine. Your old config and other hidden files should be saved in a backup by the installer. I always recommend a copy of mail folders and other apps that you may have tweaked along the way onto external media just in case.
I believe folks have tried the upgrade route by altering their apt sources and you may of course use any method you find suggested in the forum via the search tool.
Thanks!
