#1 2022-02-19 17:38
hugbear
[SOLVED] Windows installer (4.6-r1) hangs at the end of .img download
The Windows installer hangs before the end of the .img file download (on one occasion the progress "Remaining time approximately 10s" has been displayed for at least 45 minutes).
The problem is persistent: I couldn't get past this point after several attempts on two different Windows 10 machines (one of which is an almost fresh install with no third party antivirus).
Sorry, I'm too "young" to post direct links:
https://ibb.co/FBVR0sg
https://ibb.co/W6bYJ5k
https://ibb.co/YfFk2J6
https://ibb.co/m5VHjQJ
#2 2022-02-19 19:32
Re: [SOLVED] Windows installer (4.6-r1) hangs at the end of .img download
Please attach the following file:
c:\users\<username>\appdata\local\temp\wubi-4.x-rev342.log
Your account has been promoted to post links and attach files up to 300Kb. Thanks for reporting.
#3 2022-02-19 21:06
hugbear
Thank you for your quick reply.
Here's the log you requested.
L.E. The installer still freezes at the end of download.
#4 2022-02-19 23:29
We have updated download location, do one more attempt to install Q4OS and post back the result, please.
#5 2022-02-20 12:26
hugbear
Well, that was fast...
The issue is solved, the install went without a hitch - I'm posting from within Q4OS right now.
Thank you!
