#1 2022-01-14 08:17
Boot is stuck after /etc/fstab edit
Hi,
I have edited /etc/fstab to add this line:
UUID=d4da2a9b-45ca-4abc-8380-82d005d2afa9 /media/sdcard ext4 defaults,noatime,discard 0 0
(related to my earlier post)
Now, the boot process begins normally but it is interrupted and displays this message:
You are in emergency mode.
Cannot open access to console, the root account is locked.
Press enter to continue.
It displays this endlessly each time I press enter.
Any suggestion to make my system usable again would be greatly appreciated.
Thanks.
Edit.
Just after my post, I had the idea to boot on an USB key and to access my SSD to re-edit /etc/fstab in order to remove the bad line.
Now my system boots again normally.
But I still would like to have my SD card mounted for all users, not only for root.
