#1 2022-01-09 00:33
joey_linux
is there a way to upgrade to 4.7 without a clean install
Hi,
I'm currently running 3.15 and would like to upgrade to 4.7, with out having to do a clean install and re-installing all my programs. Is there a way to do this? I'm coming from ubuntu mate and linux mint where the upgrade-manager does it for you or you can "apt install" a program to upgrade the system (like older versions of mint). Is there something like this for Q4OS? Also will I have the same problem when version 5.x comes out?
Thanks,
Joey
#2 2022-01-09 03:04
Re: is there a way to upgrade to 4.7 without a clean install
joey_linux wrote:
Hi,
Thanks,
Joey
Yes, there is. Read here https://www.q4os.org/forum/viewtopic.php?id=3887
