#1 2021-12-31 15:13
linux_user93
How to make Q4OS boot faster?
Hello,
my laptop takes 3 minutes to boot. Is it possible to make it faster to boot?
It is a:
Acer Aspire1690, more than 10years old
32Bit
Intel (R) Pentium(R) M processor 1.73GHz
Q4OS version is: Linux q4os-desktop 5.10.0-10-686-pae #1 SMP Debian 5.10.84-1 (2021-12-08) i686 G NU/Linux
And other question I have is, is it possible to skip all the information, I mean all the code lines that show up at the beginning of the booting process? Is this normal?
edit: I have run the command systemd-analyze blame, check screenshot, the first things take up the most time...possible to fix that?
thank you for your support!
#2 2021-12-31 18:24
Re: How to make Q4OS boot faster?
linux_user93 wrote:
Hello,
It is a:
32Bit
No screenshot here. Copy/paste the output from
and when you do use code blocks, please:
[ code ] command_output_here [ / code ] No spaces between brackets, I just did it that way so you could see them, otherwise you'll see this:
command_output_here
#3 2021-12-31 21:09
linux_user93
I am going to post only the first ones because they take up the most time...check the foto...
I also saw a comment under a yt video(the video was about making linux boot faster) where one said that you should update your bios too...
is that safe to do? would it work on this old laptop?
#4 2021-12-31 22:28
Not sure how much difference could it make, but you can disable ModemManager.service with
sudo systemctl stop ModemManager.service
then
sudo systemctl disable ModemManager.service
and you can mask the service, so it doesn't get enable in an upgrade or something
sudo systemctl mask ModemManager.service
As for logrotate.service, you can check in /etc/logrotate.conf and try commenting these lines:
# see "man logrotate" for details
# rotate log files weekly
weekly
# keep 4 weeks worth of backlogs
rotate 4
In konsole run
sudo nano /etc/logrotate.conf
and edit those lines so they look like this:
#weekly
#rotate 4
Save the file, reboot and check if boot time is(slightly)faster. And I'm not entirely sure, but you can try too
sudo systemctl disable logrotate.service
#5 2022-01-01 11:26
linux_user93
I dont understand the second tip.  I am new to linux and the second tip just doesnt make sense to me. Or am I overseeing something? I have opened the /etc/logrotate.conf file but what am I supposed to change? I think you have posted the same thing twice.
#6 2022-01-01 11:30
linux_user93
hey and the first tip worked, it boots a few seconds faster now! thank you for your support!
#7 2022-01-01 13:16
linux_user93
oh wow! I cant believe it! the # !!! its the # ! I overlooked that one! I am gonna try that now
#8 2022-01-01 13:27
linux_user93
I tried that, but I cant edit anything. Its not possible to put a hashtag! the system gives me no pop up what so ever that tells me that I am not allowed to edit. when I try to write it doesnt write anything
#9 2022-01-01 16:21
You need to edit the file with administrative rights, so in the terminal(konsole)type
Type in your password when asked, and hit enter. Once the file is open in nano, make the changes, to save hit Ctrl + o hit enter, then press Ctrl + x to close nano.
#10 2022-01-01 20:47
linux_user93
ok thank you, that worked. I am now down at 2min and 25s...
#11 2022-01-09 00:22
joey_linux
Hi linux_user93
It sounds like you have a mechanical hard drive in this laptop, have you considered upgrading to an SSD. I had the same problem with my daily driver computer (an upgraded Dell Vistro 200, about 14 years old) and my secondary computer (an upgraded Dell dimension 8300, about 18 years old). With a mechanical hard drive my  daily driver took about a good 2 or 3 minutes, with an SSD it boots in 10 ~ 20 seconds. I got my secondary computer from 2 minute boot time down to 30 ~ 35 seconds with an SSD.
Also, as mechanical hard drives age they slow down (because there sector times increase), this could also increase your boot time.
You can get a good 250GB PNY SSD for about $30 on amazon, a slightly used 150GB Intel SSD on Ebay for about $10 and a slightly used 80GB SSD for about $5 on Ebay
With this, the tips above and Q4OS you should be able to boot in under 30 seconds and have a very fast computer
Hope this helps,
Joey
