#1 2021-12-16 20:00
Kees-D
Loading pictogram
Hi,
First, thanks for this fantastic distro!
But i have a question. When starting a program you see a loading icon, moving up and down. I just want that round loading circle, that sometimes appear when loading other things. I hope you understand what i mean!
Is it possible to change that?
Thanks in advance!
#2 2021-12-16 23:51
Re: Loading pictogram
Kees-D wrote:
Hi,
Thanks in advance!
Are you using Plasma or TDE? If Plasma, then you can go to System settings > Applications > launch feedback However, I'm not quite sure whether you can change what icon to use, I think it uses the program's icon only.
#3 2021-12-17 19:43
Kees-D
Thanks for your help!
Changed it to blinking instead of jumping. A simple turing circle would be preffered but seems not possible to change it to that.
Kind regards, Kees
