Bonsoir,
Je viens sur le forum car j'ai deux cartes graphique :
NVIDIA GeForce GF-8500GT 512Mb DDR2
GAINWARD GeForce 8600GT 512Mb DDR2
Impossible de lancer l'installation ou même après l'installation Q4OS 4.6 et 4.7 que ce soit en 32 ou 64 bits avec ces deux cartes graphique alors que j'en ai besoin.
Le problème que j'ai, ça va commencer à se lancer est dans les lignes de commande avant de lancer l'interface, l'image se bloque et impossible d'aller plus loin même avec le mode sans échec.
Y'a t'il une solution svp ?
Merci d'avance
Google translate :
Good evening,
I come to the forum because I have two graphics cards:
Unable to launch the installation or even after the installation of Q4OS 4.6 and 4.7 whether in 32 or 64 bits with these two graphics cards when I need them.
The problem I have, it will start to launch is in the command lines before launching the interface, the image hangs and cannot go any further even with safe mode.
Is there a solution please?
thanks in advance
Personne pour m'aider ??
Nothing for help??
Your post, even in French (my mother tongue), seems unintelligible to me. I don't even know if Q4OS installation does not start, hangs or terminates: you report all 3 cases. If the installation hangs, than it would be helpful to know at which step it hangs.
I only can suggest you install 4.7 and to choose 32 or 64 bits to match the processor inside you machine. If you have two graphic cards plugged into your computer, special attention to graphics configuration (available?) might be required.
I also advice you to be careful with Google translation: if your original text in French doesn't have correct phrasing, spelling and grammar, the automatic translation might be nonsense.
Anyway, don't give up.
