#1 2021-12-01 16:18
Miefodij
Bourbon menu user image (Trinity)
I have the same problem both in the Centaurus and Gemini releases of Q4OS. I can't seem to find a way to change the user image in the Bourbon menu (in Trinity). Clicking on the image in the menu does not work. Most screenshots of Q4OS that I've found do not include a custom user image, so I initially thought it wasn't possible to change it at all. But the 5th image on the Q4OS main page (called image2.jpg) has a butterfly image. I know it's the butterfly.png image that you can set as your user image in System Administration/Login Manager. The images I set there appear during login but this does not affect the menu in a way. Is there a way to change the user image in the Bourbon menu? I will be most grateful for any help you can offer.
#2 2021-12-01 17:59
Re: Bourbon menu user image (Trinity)
TDE control panel > Security & privacy > Passworrd .. > top left image button > select a user image
#3 2021-12-01 18:11
Miefodij
Brilliant! Thank you so much.
